EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
current driver is saturated problem
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: current driver is saturated problem (Read 564 times)
john23
Frequent Contributor
Country:
on:
May 31, 2025, 12:59:41 pm »
Hello ,I have built a PID controller which is connected to differential driver by the manuals below.
The PID is single ended while the driver is differential so I connected the two using converter.
The key component is the integrator.
I want that the driver to create a current on the load so It will be following the integrator output signal.
However as you can see that as integrator output rises the driver current saturated as some point .
Is there a way to fix the driver so it wont sature so quickly?
Ltspice files are attached.
https://www.analog.com/en/resources...ne-driver-receiver-design-guide-part-two.html
https://www.analog.com/en/resources...n-single-ended-to-differential-converter.html
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
