Author Topic: current sense  (Read 4980 times)
Offline electros6Topic starter
current sense
« on: September 13, 2013, 10:11:34 am »
Hi guys ,
           I am working on a project where I want to implement high side current sense on a 48V dc supply rail. Please guide me
Offline TerminalJack505
Re: current sense
« Reply #1 on: September 13, 2013, 10:25:35 am »
I'd use one of the ICs dedicated for this.  TI's INA169, for example.
Offline tszaboo
Re: current sense
« Reply #2 on: September 13, 2013, 11:28:49 am »
Self advertising:
http://nandblog.com/current-shunt-monitors/
I suggest the INA19x series.
Offline Andreas
Re: current sense
« Reply #3 on: September 13, 2013, 07:04:54 pm »
LTC6101 or LTC6101HV
With best regards
Andreas
Offline tree
Re: current sense
« Reply #4 on: September 13, 2013, 10:31:38 pm »
MAX4372.
I used that to build a battery monitor when I was an intern at NASA. One of the high ranking EEs advised that we use that chip because it's a legacy component (i.e. flew successfully on previous missions)
Offline tszaboo
Re: current sense
« Reply #5 on: September 13, 2013, 10:50:02 pm »
MAX4372.
... is a 28V part, which will fry with 48V.
Offline tree
Re: current sense
« Reply #6 on: September 13, 2013, 10:52:01 pm »
MAX4372.
I thought he meant he has to monitor current on a 48V rail. (i.e. not necessarily running the chip on 48V)
EDIT: Never mind. common mode is limited to 28V.
« Last Edit: September 13, 2013, 10:53:40 pm by tree »
Re: current sense
« Reply #7 on: September 14, 2013, 05:53:47 am »
http://www.analog.com/en/circuits-from-the-lab/CN0218/vc.html
Just released as a current monitor with a 500V CMMR range.....
Even has a video on the channel.
Offline nctnico
Re: current sense
« Reply #8 on: September 14, 2013, 10:02:53 am »
This is a very expensive solution. Its better to use a hall sensor from Allegro if you need high voltage isolation. The Adum5xxx parts look nice though. I've used one to isolate a circuit to meaure the mains voltage.
« Last Edit: September 14, 2013, 10:06:11 am by nctnico »
Offline fcb
    • Electron Plus
Re: current sense
« Reply #9 on: September 14, 2013, 10:20:36 am »
To some extent it will depend on what bandwidth, accuracy, current & calibration you want.
The gold standard would of-course be a differential amplifier across a nice little low-tempco 4 terminal shunt. Perhaps you can afford a little current drain from both sides, in which case you could use potential dividers to make that 48v a bit easier to interface to.
However at 48v (4 lead-acids, telecoms 36-72v, mic phantom powering, PoE, PSU, traction...?) we would need to know a little bit more to really advise.
*NOTE/RANT* - when I started out in electronics MAXIM used to send out these little blue & white pamphlet/magazines (perhaps they still do?).  I often used to design using stuff from them - same goes from National/TI/ST, even when the BOM wasn't an issue, the sourcing of these parts was always a headache.  Nowadays I'm loathed to change from designing in LM358/NE5532/TL072/LM339/ULN2803A, etc unless absolutely necessary.
**THAT SAID** - I love the Allegro ACS parts that nctnico talks of.  Just finished a design job with them in - real pleasure to do.
