Author Topic: Current sensor datasheet ACS 715  (Read 2560 times)
Offline sandyTopic starter
« on: August 03, 2014, 04:26:11 pm »
Hi, The datasheet for ACS 715 current sensor from allegro, shows a vout   from 1.5V to 4.3V for input current of  5A to 20A (page7 of datasheet). If we  want to measure from 0A-20A , then is it possible to measure below 5A? . It is stated in datasheet that it can measure from 0-20A , them why  the spec , can someone help me with this. Rgds
Online nctnico
Re: Current sensor datasheet ACS 715
« Reply #1 on: August 03, 2014, 04:42:24 pm »
The swing of the output amp is limited. If you need to measure from 0 then you need a bipolar device.
Offline dannyf
« Reply #2 on: August 03, 2014, 05:00:11 pm »
Sure. Though measuring very low current (ma for example) is likely difficult.
Likely due to reduced accuracy. Same thing with other high side sensors (different beast).
Offline Asim
« Reply #3 on: August 03, 2014, 05:24:01 pm »
If you check page 9 you will find the full scale graph.
The graph in page 7 is probably showing the linear region? ( this is what it looks like for me )
Offline mij59
« Reply #4 on: August 03, 2014, 05:28:54 pm »
The sensor is kind a noisy, take a look at page 10 of the data sheet.
