There is datashet of CTSA016 (100A/40mA) and this is best I can find on net.
There are no charts of burdens but maybe some hidden information I missed.
I believe the ratio is 2500:1.
There is schematic with P6Ke transient diode. I have this type. I test transformer with open secondary and primary at 50A for about 10 minutes just to check if something will overheat, but nothing happend. On the output I see near square wave about 12V peak/peak. (I know that CT should not operate without load and transient diode kick in)
There are rated voltage of 0.333Vac, but not max voltage. 0.333Vac means about 0.94Vpp, and I wish to have about twice of that.
As with open secondary device doesn't overheat I assume it will be safe to operate with burden to get 0.7Vrms. Probably not accurate/linear on upper half. In reality I need to be as precise I can get up to 4A, and distortion over that is not so important.
Somebody see some risks?
