Here's a picture of the SoC running a simple demo program, along with the source file, and the debugging output of the assembler. The program polls the UART, and when a char is received, it displays it on the screen, while handling backspaces as delete and displaying a cursor. It also displays each char in binary on the LEDs attached to the GPIO, and echos the char back over the UART. This is a simple demo of most of the features, except it doesn't include the use of counter/timers, or the interrupt system. The Arduino that you see in the picture is only acting as a USB to serial bridge for the FPGA.
.define dir_reg, 0x00
.define port_reg, 0x01
.define pin_reg, 0x02
.define uart_baud, 0x0A
.define uart_ctrl, 0x0B
.define uart_buffer, 0x0C
.define gpu_addr, 0x2000
.define gpu_ctrl_reg, 0x80
.code
ldi r0, 0xff ; set all gpio to output
out r0, dir_reg
ldi r0, 0b00011100 ; setup the gpu
out r0, gpu_ctrl_reg
ldi r2, gpu_addr[l] ; setup the pointer to the v-ram
ldi r3, gpu_addr[h]
stable: in r0, gpu_ctrl_reg ; wait for gpu clock to become stable
ani r0, 0x80
jz stable
ldi r0, 103 ; set the baud rate to 9600
out r0, uart_baud
loop1: in r0, uart_ctrl ; poll for full rx buffer
ani r0, 1
jz loop1
in r0, uart_buffer ; capture the data
loop2: in r1, uart_ctrl ; poll for empty tx buffer
ani r1, 2
jz loop2
out r0, uart_buffer ; echo the char back over the uart
out r0, port_reg ; write the data to the gpio port
cpi r0, 8 ; check if delete was sent
jnz normal
ldi r0, 32
srd r0, p2 ; print space to clear cursor, and move back
ldi r0, 95
str r0, p2 ; delete char and print cursor
jmp loop1
normal: sri r0, p2 ; write the data to the screen
ldi r0, 95
str r0, p2
jmp loop1 ; go get another char
