Author Topic: CX101B Display  (Read 2106 times)
Offline kvrestoTopic starter
CX101B Display
« on: October 25, 2015, 12:14:26 am »
Hi Everyone.
I want to be able to display a negative voltage in a panel meter for convenience, but from the one page data sheet of the CX101B I cant tell if I can simply feed a negative voltage into it just as I would into a multi-meter. I was going to buy one and try, but, why blow it up if it turns out it doesn't work like that.
cheers
kvresto.
Offline Andy Watson
Re: CX101B Display
« Reply #1 on: October 25, 2015, 12:22:22 am »
Datasheet says "Auto polarity", so I would assume yes - it will display negative voltage.
Re: CX101B Display
« Reply #2 on: October 25, 2015, 07:47:41 am »
cheers.
