Author Topic: Data interface circuit mic-in android decoding POCSAG(1200)  (Read 5590 times)
Offline tek2232Topic starter
« on: March 08, 2018, 06:44:15 am »
Hi everyone, :)
I build this little circuit that makes it possible to connect
a receiver (scanner) to the audio jack of an Android phone/tab.
It is powered by the audio jack itself.
I tried it with three different scanners and several phones and
tabs,so the circuit and software is somehow "tuned" to these
devices.(see results down below)
Maybe someone who finds this interesting can try
this circuit and app to see if it also works on his setup
and can this circuit be improved ?
The microphone input carries a DC voltage about 1.4 - 2.2 v
(depends on manufacture device),this voltage is used to power
the BC548B which is used to buffer the earphone or the discriminator
output from the scanner.
The limiting resistor R1 and capacitor C1 protects the earphone or discriminator
output from the receiver against overload.Resistor R4 enables external mic in.
To see if this idea really works I thought lets find a transmission protocol
not to fast and not to complicated.
I ended with the POCSAG(1200) protocol it is used to transmit
data to pagers and is well documented.
If POCSAG is decoded most often the unfiltered audio from the
receiver is used (discriminator-output).
Some scanners have a discriminator output build in ,but most don't.
I didn't want to crack open my brand new receiver and
do some "precise" soldering ,so I thought lets try also to decode using
the earphone jack from the receiver,and then there came
some problems. :palm:
When audio is heard through the speaker you can hear a 600Hz tone
these are the POCSAG preamble bits ,next follows sync en data.
In the picture above is shown how much the earphone signal
is distorted when compared with the digital discriminator signal.
The receiver amplifier has an analogue filter at its output
causing this distortion,it seems that the signal collapses
or rizes after one bit high or one bit low,this is why it's
so hard to decode with the earphone signal.
Also each type receiver has different filters and amplifier so
a standard setting is almost impossible see picture above.
Another problem is the different specs of the MIC-in circuit
from the different manufacturers of android devices which
results in different amplitude levels when using the same
receiver but different devices.
So after all this how can the right audio level be found.
Well it's been tried with two trigger values one for the
preamble to get the right timing and one for the data and it
gives some promising results.
Playstore :
[url=https://play.google.com/store/apps/details?id=datainterface.com]https://play.google.com/store/apps/details?id=datainterface.com[/url]
More info under the "Help" button in the App.
JP
« Last Edit: April 19, 2018, 06:45:36 am by tek2232 »
Offline vk4go
Re: Data interface circuit mic-in android decoding POCSAG(1200)
« Reply #1 on: July 22, 2018, 09:31:16 pm »
I make this but it not works.
I try out with 3x Android mobile phones and a Lenovo Tab 4 8.
I use all the schematic parts on a vero board.
Is here anyone with a clue what I am doing wrong ?
73 Art
« Last Edit: July 22, 2018, 09:38:28 pm by vk4go »
« Reply #2 on: July 23, 2018, 06:46:00 am »
Hi Art,
With four different devices maybe it could run on one of them.
I will send you a pm how it could be done .
Just for testing if your circuit is ok you could install  a Scope app on
the device to see if there is any good signal  available,check it
with the graphs above.
(Free Apps are Oscilloscope , SmartScope )
Jp
Offline quantenquark
« Reply #3 on: November 21, 2019, 05:01:03 pm »
Hi JP,
this is a very interesting post.
I have build the curcuit on a bread board and played a little bit with the resistors and my THF-7E using unfiltered audio signal (TNC mode, 9600bps)
Finally I can decode the POCSAG beacon but have some issues with the alpha messages. IT happened 2 or 3 times that I could read a part of the message.
Regarding the tolerance, which kind of resistors are needed here? I have used carbon ones which have 2-5 % tolerance.
Will now try with my oszi to get an idea if the signal is bad.
Is there anything else what can be improved?
regards
Quanti
Offline coppice
« Reply #4 on: November 21, 2019, 05:11:14 pm »
It feels so strange that there are still POCSAG transmissions to decode in 2019. :)
« Reply #5 on: November 21, 2019, 05:20:35 pm »
Yes, it is!  ;D
But sometimes this technology is still used and need to be maintained.
Anyway, in parallel I am building and programming an interface to show the specific alarms send by the fire brigade control center so that my team has a better overview when they reached the wake.
Of course, today we use TETRA but the messaging is still processed via POCSAG.
 It is a  funny world we are living in.
73 Quanti
« Reply #6 on: November 21, 2019, 06:47:55 pm »
Hi JP,
regards
Quanti
Hi,Quanti
Carbon resistors are ok ,and a breadboard works fine
to try something out.
You can check with your scope if the output signal from
your scanner stays the same when you connect the interface.
If you can are already receiving some characters from a message
then your almost there.
I think unfiltered audio signal (TNC mode, 9600bps) is the
same as discriminator output?.
It's a little bit strange but the earphone audio signal can give good
results when a discriminator output  isn't working properly or doesn't work.
I should try this first and tweak with the prTrig and Trig values
Keep the  peakvalue about 16000 if possible with the volume button
from your THF-7E.
What kind of smartphone or tab do you use to decode ?,
Try different ones some preform better.
JP
« Reply #7 on: November 26, 2019, 05:47:31 pm »
Ok, just have seen this message. Thank you for replying to me.
I assume that TNC/9600 is same like discriminator output accoring to the manual as it is used for packet radio.
Should be more or less equal.
Will compare the results before and after connecting my devices. I use Samsung A5 / A8  and a Galaxy 10 Tab .
What is not really handy to me is the peak value, I need to figure it out and will send a screenshot if needed.
regards
Quanti
« Last Edit: November 26, 2019, 06:00:15 pm by quantenquark »
