senso/others: yes, i will reply. sorry for making you to have wait, but i dont have now much time to reply or read, as i previously written. i will try to reply within a few days. i have found a bugs in the os that also must be fixed, and i have other things to do. i received totally more than 500 comments and questions from the OS. please be patient, and sorry for the wait.
What i'm afraid of is someone will believe you and your "next best thing" ramblings and actually part with their hard earned real money.
What are you emulating this thing on?
cgroen: i guess the great way to profit from my *some* skills would be to do works directly for you, while you watching tv from the money i earn you. these times ending in the IT market nowdays.
For your next greatest achievement, build an operating system using only 1 instruction...nop
professionals ?
professionals ?
of which sector?
here we have a guy that can apparently write an os but can't write a tcp/ip stack (if he's so paranoid about using other people's code)
what's going on next? no usb?
i thank whoever pointed to Temple OS, i totally forgot about that
2017, march 16. - Compiler ang GUI bugs
Several bugs fixed in the compiler related to inline function calls and runtime library.
A bug sometimes caused missing re-rendering of texts.
now i have a bit time, and i will make now very short answers to the newer questions.What i'm afraid of is someone will believe you and your "next best thing" ramblings and actually part with their hard earned real money.
what im afraid is that masses buying 400 usd x86 cpus with 200 usd motherboards and 600 usd graphics cards becouse millions of people fake-expertising them, and posing for them with little knowledge with they little bash scripts, routers, shitty games in forums, governments, corporations and chaining humanity to these ineffective, slow and dangerous technologies, becouse they refuse to learn, innovate, and make any notable technologic expansion in the last 25 years.
free_electron: from what viewpoint dawn is obsolote? its more modern in every aspect than android, windows, or linux.
helius:
DBecker: thats what is usually happening with the operating systems, and most of the software. there is a good and effective implementation, which boots instantly, works very fast with very small resources, and as more and more people starts to work on it, from time to time it starts to gain more ,,weight'', its becoming slower, people start to add random unnecessary things that making it even more slower, and in the end you need gbytes of disk space to gave. thats what happened to windows from 95 to 98, from 98 to xp, and from xp to 7. and thats what happened to linux too. these versions bring a lot of better icons, better kernel and hardware compatibility, but in reality they just growing and growing, without any real innovation. now if you want a debian with lxde, text editor, etc, you need 2 gbyte of disk space, and an 1 ghz cpu to have it working, while the 4-5 year old versions needed only 1 gbyte and a 600-700 mhz cpu to achieve the same things. at this rate, a working linux distribution with the basic packages will require minimum 8 gbyte disk and 2 ghz cpu by 2020. this is a kind of problem i dont want in dawn, so i actually limited the boot ,,fragment'' of the disks to fix 256 mbyte. i agree that writing a compiler is very hard, with the compiler alone was more work probably than the other parts of the os.
ataradov: folowing your logic, linux cant even called a real os, becouse it have no piano or chess built in while my system can. pointing some features important for you will not decide what an OS is, there are several os-es for different purposes, and i am pretty sure if i would hack the networking out from linux will still boot much slower than my system. also my system has networking, its just not tcp/ip based, so saying it not have networking is bullshit, becouse it technically has.
senso: the best advantage of subleq is the simplicity of the build-up. this makes it easyer to design, manufacture, as it discussed before. currently you can buy an fpga, and do a subleq design for your own. later i will contact to some subleq-oriented persons with related fpga developments, so there will be maybe available to just download one directly for the people who wants it. the tcp is overdiscussed, the 50 ghz was wrong data and i removed that section from the website.
I will say that out of curiosity I download the compressed thing, uploaded it to virustotal, and ran the exe inside a VM, and its very,very,very slow(in a i7-4700mq in a laptop with an SSD), I tried to use it for 20 minutes, but its way to slow to even try out.
For all the bad things that Windows10 as, I find it amazing that I can get a random core2duo laptop, install it, and everything works, even the Fn combos for brightness and sound control.
it is obsolete because
- there is no hardware to run it (only emulation)
- nobody will ever build the subleq cpu in a commercial setting
- the writer of the OS does not allow for connectivity to other machines.
- the writer of the os does not allow anyone else to write code for it.
so yeah. it is obsolete.
The conspiracy theory angle on every consolidated technology and even open standards.
The conspiracy theory angle on every consolidated technology and even open standards.Which I thought was odd and very hypocritical too, as the OS isn't even open source.
The website talks of freedom, which is very misleading, given the proprietary nature of the operating system.
