Author Topic: Decapping, imaging, and reverse engineering all the 54xx/74xx chips  (Read 7618 times)
Offline robertbaruchTopic starter
Well, as many as I can get my hands on. It's fun. Yes, it's going to be a lot of work and I will likely not get to every number and variant, but I plan to do a lot. I'm putting all the info on project5474.org. Why? Why do we do anything? ¯\_(?)_/¯
The following users thanked this post: bitwelder, MagicSmoker, edavid, diyaudio, ebclr, PointyOintment, evb149, _Wim_, orolo, MK14, JPortici
Offline Vgkid
Re: Decapping, imaging, and reverse engineering all the 54xx/74xx chips
« Reply #1 on: March 27, 2017, 05:26:04 am »
I look forward to your updates.
Offline ebclr
« Reply #2 on: March 27, 2017, 08:36:37 am »
Will be interesting to see different manufacturers for same part  imaging, to check what they do diferently
Offline bitwelder
« Reply #3 on: March 27, 2017, 02:21:05 pm »
It would be interesting also to read about the process and the equipment used.
The following users thanked this post: Sbampato12
Offline MK14
« Reply #4 on: March 27, 2017, 04:19:08 pm »
That sounds like an interesting and fun project.
I hope you manage to get around to the 74181 (74182 is probably fairly rare), 4 bit arithmetic logic unit, and its partner, the 74182 is a high speed carry look ahead generator.
I'm also interested in the differences, between the original 7400 series, and the S (Schottky) and LS types.
Offline SingedFingers
« Reply #5 on: March 27, 2017, 04:22:10 pm »
74LS469 is rumoured to be an interesting one. Apparently it's actually a PAL, not custom silicon.
Offline free_electron
    • SiliconValleyGarage
« Reply #6 on: March 27, 2017, 04:57:21 pm »
I hace somwhere a 74 series 16x16 multiplier in 64 pin humonguous package ...
Offline pyroesp
    • Nicolas Electronics
« Reply #7 on: March 27, 2017, 07:18:21 pm »
Favorited the website for future read.
Do you have a list of ICs you currently have/don't have ?
From my IC list I've made quite a while back, I've got four 74181 and three 74182. Don't know what type (S, LS).
Above mentioned list, it seems I have thirty 7400, I'm guessing I should have all sorts.
If OP wants to and is willing to pay for shipping cost, I'll send a few of those I have in surplus to him.
« Last Edit: March 27, 2017, 07:48:31 pm by pyroesp »
The following users thanked this post: MK14
« Reply #8 on: March 27, 2017, 09:12:28 pm »
I have a list of ICs.
Also I have a Patreon.
« Reply #9 on: March 27, 2017, 09:16:08 pm »
I do eventually plan to put the full processes I use on the wiki -- I currently only have "Heat", "Delayering", and "Annotation", still working on "Imaging" and "Hot Sulfuric Acid". But a lot of the information is on my (separate) blog if you're interested.
If you do have chips that aren't on the spreadsheet, please let me know!
Online RoGeorge
« Reply #10 on: March 27, 2017, 09:27:45 pm »
Does anybody know what/why are those "bubbles like" dots, and why are those present only on the white traces, please?
« Reply #11 on: March 27, 2017, 09:50:02 pm »
From what I've seen, they seem to be on every top metal layer. Maybe it's just that the process used for depositing metal leaves a lot of gaps. So then they would run the depositing stage for longer to ensure a solid connection. Just a very rough surface.
In one decap session, I removed the top glass layer by etching it for a very long time. I got under-etch underneath some of the metal connections, which caused the connections to lift off the surface. There were still those bubbles on the surface of the metal, so I'm pretty sure it's not on the glass.
Offline amyk
Offline MK14
« Reply #13 on: March 28, 2017, 12:52:44 pm »
The '181 has already been done: http://www.righto.com/2017/01/die-photos-and-reverse-engineering.html
Thanks!
That is a really great investigation and report into what is inside a 74181. Their detailed explanation of how the transistors work, to make the overall circuit, is just brilliant!
Anyway, nice find.
If decapping TTL chips. The 74181's would still be the (top) one to go for, on the basis that it is one of the biggest and most complicated (of the "older" TTL chip parts). It has a lot of the functionality of a microprocessor, and yet was released before them and used in many historically important computers, of the time.
I.e. It is so big and functional, that it makes it very interesting.
Simple gates, e.g. 7400 Quad Nand, are still interesting. But the very complicated ones (like the 74181), add a lot to how interesting it is (at least for me).
I'm not sure if the OP is going to only do TTL chips which have not yet been publicly decapped, or if they are doing them all, regardless. I get the impression they (OP) are doing this independently of any other works, available on the internet.
« Last Edit: March 28, 2017, 01:10:24 pm by MK14 »
« Reply #14 on: March 31, 2017, 05:36:45 am »
I know the guy who did the '181, he also gave me a '182. I think his work on the 181 is good enough to put on project5474, but basically I'm shooting for doing independent work, on whatever I can find. Not necessarily sticking with the older ones, though. They are still making new 74-series chips all the time, and there are still lots above the 74700 range.
« Reply #15 on: September 10, 2017, 12:07:32 am »
LOL, I just realized: I don't turn on TTL chips, I take 'em apart.
Offline MK14
« Reply #16 on: September 10, 2017, 02:17:45 am »
You're turning them into ALZ chips.
Where A.L.Z. = Always Logic Zero = Permanently Disassembled (a.k.a. Broken).
TTL = Transistor Transistor Logic
Where Transistor in this case = Acid Dissolved Case = ADC = Always Digital Clear = Logic Zero
