You're not switching the voltage, you're switching between two resistors on the feedback of the switching regulator.
i know about this but i was referring to the solution where i have 12v input, this way i need 15v input.
I can use this module:
https://www.lcsc.com/product-detail/Power-Modules_HI-span-style-background-color-ff0-LINK-span-HLK-15M15C_C5120968.htmlwhich outputs 15v to deliver it to your suggested triple buck IC, which I really found it a month ago when I was searching. I don't really know if this total price will be lower than my own using AP62300.
meanwell irm-20-15 is +8.3$ for 100 quantity while above module is about 2.5$. meanwell is better name brand + does not require external protection components while hi-link does. even mornsun module LS15-23B15DR3 requires external components.
mornsun LD15-23B15R2-M seems cheaper and does not require much external components.
so now i have 4 options:
1- use very cheap Hi-link module and build all input protection myself.
2- use Mornsun LS15-23B15DR3 module and build all input protection myself, similar to option 1.
3- use Mornsun LD15-23B15R2-M module, just put a mov and input series resistor as everything else is inside.
4- use Meanwell module which has everything built in.
money-wise, full input circuit protection is going to be around 1$ or so.
rough estimate for options in 100 quantity:
1 = 3.5-4$.
2 = 6$
3 = 8$
4 = 9-10$
For example, Richtek RT2723 is around 1$ on lcsc, around 2.12 EUR if you get 10 at Mouser , around 2.4$ at Digikey if you buy 10, but has 3 outputs, supporting 3A/2A/2A continuously , or maximum 3.5A/2.5A/2.5A
Using Richtech one, Vout1 = 5v, Vout2 = 3.3v, Vout3 = 9 or 12v by switching feedback resistor. certainly can be done but the issue is that the power supply area is a rectangle with about 50mm width or less. no big room but will see if i can make it work.
evaluation board used relatively cheap inductor, 4.7uH with about 23mOhm resistance. I prefer using highest switching frequency but lower resistance inductors will be big in size. achieving low ripple is important but also low heat. looks like for 2.2 mhz i need 600kohm resistor. what do you use in such situations to achieve smallest ripple available with good thermals?
for filtering output caps, i could still use the 22uF 1210 X7R ones I used before... plus some polymers in parallel. having lots of ceramics in parallel can be achieved in small spaces.
there is the compensation which i am always afraid of. they suggest 4.7nf cap in series with 20kohm resistor for the output caps of 44uF ceramic. they suggest doing a ratio to reduce it for 22uf output caps it should be 10k resistor. this way if i want 4x22u = 88u caps + 470u poly it would be very small compensation cap... more like 1.58k ohm or something. i could not find an equation to do it.
it is fair to say that I need more filtering caps for the big amps rail of 5v 2a, the others 3.3v at 0.6a or 12v\9v at very low amps probably won't require more than 2x22u ceramics.
__________
I am kinda confused now since I wanted this PSU to sell for max of 60$. if i go with best options:
meanwell irm-20-15: 8.5$
richtek switcher: 0.8 (assume all from lcsc, which now is just 24 units in stock)
ceramic caps: ~0.3
other caps: 0.2
resistors: 0.1
connectors: 2 or so
pcb: 7.5
inductors: 0.6
total = 20$ for 100 quantity. more for less quantity.
it can be sold for 60$ and even for 50$ but if i have the other options i could save more.... if you were in my place, what would you choose?
