Go to Ebay and look up the Elgar AC Power Sources. They're made specifically for what you want to do. They're heavy and expensive to ship so there's practically no market for used ones so if you can drive to the seller's location and pick them up in person, they can be had very cheaply IF the seller really wants to sell it and not to set on it and hoping for a pot of gold! I've bought several for less than $1 per pound weight.
The frequency is set by the plug in module so either buy one with a 400 Hz module or a variable frequency module, or buy the module separately.
One of the GOOD things about the Elgars is that they are rock solid and all their documentation is online somewhere, but you'll have to figure out what docs you need and the correct name so that you can search for it.
Other companies make similar devices but Elgar is by far the largest seller and has a wide selection of power, frequencies, number of phases, etc etc,
