Author Topic: Design AC-DC power supply using Innoswitch and custom transformer  (Read 3592 times)
Offline VEGETATopic starter
  • Country: jo
  • I am the cult of personality
    • Thundertronics
Re: Design AC-DC power supply using Innoswitch and custom transformer
« Reply #50 on: May 02, 2024, 07:04:14 pm »
I have decided to use this switcher IC: https://www.lcsc.com/product-detail/Power-Distribution-Switches_Diodes-Incorporated-AP22966DC8-7_C441830.html
please check schematic in attachment.
basically, i shorted the 2 inputs since the switch is supposed to switch between 2 power sources to deliver to one output.
will this cause problems like shorting? I've put some soft-start caps to make it a bit gentle.
Online xvr
  • Country: ie
    • LinkedIn
« Reply #51 on: May 02, 2024, 07:57:43 pm »
This switch include discharge resistor on each output channel that turned on when channel disabled (as followed from schematic in datasheet). You short output from both channels, so one of discharge resistor always will be connected parallel to output. Its value is 220-300 Ohm. You can use this switch if you can tolerate such surplus load.
  • Country: jo
    • Thundertronics
« Reply #52 on: May 02, 2024, 08:58:32 pm »
worst case is 5v for 300 ohms = 16.7 mA. very tiny, won't make an effect.
however will this circuit yeild any dangerous issue like shorting?
a simpler solution is to use such a switch like this one: https://www.lcsc.com/product-detail/Toggle-Switches_YUEN-FUNG-ST-0-103-A01-T000-RS_C1788488.html
i want one which does not have luggs and stuff, but overall it is more expensive though, cheapest ever is a jumper but it is not elegant
Online xvr
  • Country: ie
    • LinkedIn
« Reply #53 on: May 02, 2024, 09:14:07 pm »
I see no danger. It should work.
