This switch include discharge resistor on each output channel that turned on when channel disabled (as followed from schematic in datasheet). You short output from both channels, so one of discharge resistor always will be connected parallel to output. Its value is 220-300 Ohm. You can use this switch if you can tolerate such surplus load.
worst case is 5v for 300 ohms = 16.7 mA. very tiny, won't make an effect.
however will this circuit yeild any dangerous issue like shorting?
a simpler solution is to use such a switch like this one:
https://www.lcsc.com/product-detail/Toggle-Switches_YUEN-FUNG-ST-0-103-A01-T000-RS_C1788488.htmli want one which does not have luggs and stuff, but overall it is more expensive though, cheapest ever is a jumper but it is not elegant
I see no danger. It should work.
