Author Topic: Design rules inverted  (Read 2131 times)
Offline compet17Topic starter
    • Youtube - Play with Junk
« on: August 17, 2015, 06:54:29 pm »
Normally designers of electronic devices (and any other things) try to keep cost and number of parts as low as possible. Every curve in a casing has a purpose, either aestetically or for technical reasons.
This device has a switch built in which has no electrical connection and no mechanical function... A free switch for everyone :-) Take it, it makes no difference.
Online helius
Re: Design rules inverted
« Reply #1 on: August 17, 2015, 07:12:06 pm »
There is another model of the Thermoscan that has a switch in that position, with markings for "Oral or Rectal equivalent".
The display location was also done that way, because the unit has a cover over only one side (covering the probe and the display).
« Last Edit: August 17, 2015, 07:14:44 pm by helius »
« Reply #2 on: August 18, 2015, 05:25:25 pm »
I have that cover too. It was one thought that they wanted to protect the LCD with that cover...
