Hello everyone,
I’m currently working on a project that involves precision analog sensors (temperature and strain gauges), and I’ve run into a challenge regarding the power supply design. The sensors require a very stable and low-noise supply; otherwise, the signal drifts and introduces measurement errors.
Here’s the situation:
The system runs primarily on a 12 V DC source.
I need to generate a clean 5 V (and possibly 3.3 V) rail for the sensors and ADC.
I tried a few switching regulators with LC filtering, but the ripple is still noticeable in the output readings.
Linear regulators help reduce noise, but efficiency and heat dissipation become a concern, especially in a compact enclosure.
My questions:
Has anyone designed a low-noise power supply specifically for sensitive analog circuits?
Would a hybrid approach (switching pre-regulator + low-dropout linear regulator) be the best compromise here?
Are there recommended regulator ICs or filter topologies that work well for this type of application?
Any PCB layout tips to minimize the coupling of noise from digital/microcontroller circuits into the analog rails?
I’d love to hear from those who have tackled similar challenges. Any suggestions, references, or even example schematics would be a huge help.
Thanks in advance for your insights!
