Hi friends,
I've been wanting to design and build a floppy drive from (almost) scratch, the only things I will be using are the read/write heads, the motors/mechanical parts.
The rest I want to build from discrete logic, both digital and also analogue where needed.
I have a good theoretical understanding of the physics of electromagnetism, but I'm not sure it will be enough.
Does anybody know of a book or online material on the engineering of floppy drives? Either 8, 5 or 3 inch formats. Preferably 8 1/4.
Thing is I really want to do this, and I will no matter what, BUT I don't quite know how a floppy works.
I see they use frequency modulation to write the magnetic data. What does this mean physically? I also know that clock data and data data are written together, so that a signal would look like a clock pulse, and then data after that. This means a low pulse on the clock, and then if there's another low pulse after that it's a 1, if not it's a 0. Does this qualify as FM ? Is this what they mean by it ?
Also, the signal coming from the head, what does it look like ? Wiggly AC pulses right ? So I'll have to clean it up with a good ADC.
Thing is, I don't need to be compatible with existing formats at the beginning. As long as I can create a drive that can write and retrieve data in SOME format, that will be enough.
So all in all, I will have to take the head, create some digital logic to control it, and then send some pulses in some order to be written.
Can anyone reccomend me a text on floppy drive engineering? Does this even exist ?
