Author Topic: did i break physics?  (Read 21631 times)
Offline neoTopic starter
  • The specialist.
« on: September 22, 2016, 03:21:36 am »
i have a 17 volt transformer i soldered a bunch of thinks together, the dip sockets being outputs as this was supposed to be for a vfd tester i was building but when i went to test it with my multimeter i found 50v where there should have only been 25, anyone got any ideas? did i break physics?
Offline zlymex
  • Country: cn
Re: did i break physics?
« Reply #1 on: September 22, 2016, 03:28:25 am »
Multimeter problems?
High frequency interference?
Analog multimeter on AC range?
Measurement is Comparison.  https://bbs.38hot.net/
  • The specialist.
« Reply #2 on: September 22, 2016, 03:36:33 am »
what high frequency? i checked it 10 times against know value and 10 out of 10 my multimeter was accurate and i dont have an analog multimeter
Offline Rerouter
« Reply #3 on: September 22, 2016, 03:39:25 am »
I havent looked at the PDF, but i experienced something similar before, a 18V transformer, measured 18V AC, but when i rectified it, measured 42V DC, had to pull out the scope to figure it out, turns out the transformer was somewhat resonant with the RFI filter caps i had used, and was spiking up to 45 volt but only for a very short period.
  • The specialist.
« Reply #4 on: September 22, 2016, 03:40:53 am »
ill test it on my oscilloscope but my multimeter wasnt flying all over the place it was rather solid value but i don't know if that means much
Offline helius
« Reply #5 on: September 22, 2016, 03:44:35 am »
Some of you may enjoy this lecture on the topic of "breaking physics":
See if you can spot what he does "wrong".
The following users thanked this post: cgroen
Offline timgiles
  • Programmer, DB architect
« Reply #6 on: September 22, 2016, 04:44:24 am »
As with all those on Youtube that claim similar, if you consider that all the scientists at CERN, spending billions of Euros, manage to 'break physics' only a few times over 15-20 years of planned operation, I doubt if you have managed it with a single capacitor!
Offline ZeTeX
  • Country: il
  • When in doubt, add more flux.
« Reply #7 on: September 22, 2016, 05:05:01 am »
Then your transformer might supply more then 17V with no load.
this is an easy test, wire up your transformer to the mains, connect it and then measure AC voltage using your multimeter.
if a transformer is sold as 12V it might supply 13V or 17V no load, because they spec 12V on it at load.
  • The specialist.
« Reply #8 on: September 22, 2016, 05:29:43 am »
its used and it was thoroughly tested to be 17 volts and you never know stranger things HAVE happened it might be 1 in a trillion for all i know but i do doubt it or i wouldnt be asking here, here is my theory i think somehow it is in series with itself or perhaps as suggesting resonating
Offline Rick Law
« Reply #9 on: September 22, 2016, 05:36:45 am »
Damn!  It was you!  I was wondering why gravity is not working for me, and I thought it was what I was smoking.
  • The specialist.
« Reply #10 on: September 22, 2016, 05:43:10 am »
:-DD :-DD :-DD this is without a doubt the funniest joke iv'e heard all year.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #11 on: September 22, 2016, 07:54:13 am »
Transformers are usually specified at full load. For a cheap, small transformer, the off-load voltage can easily approach 2x the full-load voltage, especially when you also consider variation in mains voltage.
Day Job: Mostly LEDs
The following users thanked this post: R005T3r
Offline ZeTeX
  • Country: il
« Reply #12 on: September 22, 2016, 08:12:09 am »
Maybe somehow the transformer spikes to an higher voltage and the capacitor just holds the peak, ofcourse with even a small load this will drop.
what is the W\VA of your transformer?
Offline Fungus
« Reply #13 on: September 22, 2016, 08:16:03 am »
Depends on what you mean by "transformer".
If it's one of those old copper-wire&iron things then there's no mystery, you've just rediscovered 'inductance'. Put a load on the output and it will drop down.
Offline Ian.M
« Reply #14 on: September 22, 2016, 11:18:38 am »
First I'd want to check the multimeter - a fresh 9V alkaline should read between about 9V and 9.3V on its DC volts ranges, and on its AC V ranges, assuming its CAT II or better, the mains supply (measured via a lead fused at no more than 3A - for your safety, firmly connected to your test probes so you don't have to touch or hold any part of the wiring with the power on), should read within 10% of 120V. If its NOT CAT II or better rated don't attempt to check your mains supply voltage.
TLDR: Before claiming physics is broken, sanity check your instrumentation!  :horse:
« Last Edit: September 22, 2016, 05:36:22 pm by Ian.M »
  • The specialist.
« Reply #15 on: September 22, 2016, 02:00:26 pm »
 maybe it is inductance, as for the mention of sanity checking my equipment i crosschecked it 10 times
Offline Ian.M
« Reply #16 on: September 22, 2016, 05:34:24 pm »
Photo please, so we can see the s--t you are actually testing and see how you have it hooked up.   What's the measured AC voltage across the ends of the secondary and what's the make and model of your meter?
Offline max_torque
    • bitdynamics
« Reply #17 on: September 22, 2016, 05:56:40 pm »
Have you soldered TWO output windings in series by an chance??
Ie dual tap output, both of 25V, in series you get 50V!
The following users thanked this post: daveshah
  • The specialist.
« Reply #18 on: September 22, 2016, 07:13:39 pm »
no because this is the only one though that was my first thought
Offline ZeTeX
  • Country: il
« Reply #19 on: September 22, 2016, 07:22:12 pm »
OK, upload a picture of your setup, show us your transformer, show us how you measure the transformer output voltage, show us how you measure the 50V.
Don't replay unless you have pictures - this is going nowhere.
Offline Fungus
« Reply #20 on: September 22, 2016, 11:15:09 pm »
If there's no load on the transformer then it's inductance. No need to look further.
Put a load on the output (eg. a 220 Ohm resistor) and watch it drop down.
Offline Macbeth
« Reply #21 on: September 22, 2016, 11:27:06 pm »
This whole thread reminds me of Batteriser Batteroo doing all their battery voltage tests with no load whatsoever  :palm:
The mysterious +/-17V is from what? Without anything to go on here why even bother?  :--
The following users thanked this post: TheBay
Offline Audioguru
« Reply #22 on: September 23, 2016, 02:43:25 am »
The schematic does not show a transformer and does not show a rectifier. Instead it shows inputs of +17V and -17V feeding one 1000uF capacitor and the +17V input connects to the +50V output and the -17V input connects to the -50V output.
Offline Ian.M
« Reply #23 on: September 23, 2016, 03:00:00 am »
You think that's bad, you should see his schematics in his other topic!  |O
They're about as useful as a London Tube map on the Moscow Metro.  :scared:
Offline Audioguru
« Reply #24 on: September 23, 2016, 03:00:21 am »
The schematic does not show a transformer and does not show a rectifier. Instead it shows +17V and -17V inputs connected to a polarized 1000uF capacitor and the -17V input connects to the +50V output and the -17V input connects to the -50V output.
