- Off-line 240VAC
- Current sensing at up to 15-20A max with a shunt resistor of say 5-10 milliohms.
- No Hall effect sensors or current transformers - too bulky, too expensive. Best if the solution is compact and cheap. Galvanic isolation from the mains line is not needed.
- At the moment, the current shunt is in series with the neutral line to the load, and the 5V SMPS output is relative to the mains neutral - that is, the ground from the SMPS is connected to the neutral on the SMPS input side, connected to the neutral of the mains supply. But keep in mind that the local DC ground is a self-contained thing - it's a floating, isolated system.
So, effectively, one side of the current shunt is ground and the other side of the current shunt is very close to ground - say 100mV RMS, if it is 10A RMS across 10 milliohms.
Anyway, any recommendations for a differential amplifier that might work well in this application, with a single-ended supply?
Is the AD8210 likely to be a reasonable choice, or are there any cheaper candidates?
