Author Topic: Different gnd polygon question  (Read 2727 times)
Offline KaramelTopic starter
  • Country: tr
« on: February 06, 2016, 11:21:51 pm »
I have a one question about pcb design.
Below, there is a pcb which i have found it from aliexpress. You can see clearly that, pcb has a different gnd polygon. Gnd pad was not connected directly. This was connected with wire which located inside gnd polygon.
What is meaning of that? Why did it use?
Offline ThomasDK
  • B.Eng. EE
Re: Different gnd polygon question
« Reply #1 on: February 06, 2016, 11:26:58 pm »
My guess would be that it is used as a crude current sensing resistor.
What's on the other side?
  • Country: tr
« Last Edit: February 06, 2016, 11:40:03 pm by Karamel »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: February 07, 2016, 04:00:35 am »
In cheap Chinese products, there is often no accounting for purpose or reason...
Often, slotted conductors will be used to push current flow into component pins, like a filter capacitor or shunt resistor.  That wouldn't make much sense here.
If it is being used as a shunt, that's even worse, because copper has quite low resistance and high inductance, and a terrible tempco.  So the DC voltage drop is small and extremely drifty, and the AC voltage drop is dominant at switching frequencies.
Seven Transistor Labs, LLC
  • Country: tr
« Reply #4 on: February 07, 2016, 05:24:55 am »
Hi tim. Thank you so much for your replying.
Could you show and explain any slotted conductor application? I am an electric engineering student who is attending 1st year. Sometimes, i cannot understand cleary.
Best regards. :)
  • Country: tr
« Reply #5 on: February 07, 2016, 12:06:50 pm »
Could you support your knowlage with documents or pictures? Which book do i have to read for learning this stuation?
Offline djQUAN
  • Country: ph
    • My DIY website
« Reply #6 on: February 07, 2016, 12:20:56 pm »
It is commonly seen in chinese DC-DC modules used as current shunts. Yes, it is highly inaccurate and has a high TC but it is essentially free and (sort of) does the job so they do it.
I have those CC-CV chinese modules and I traced them out so they are indeed used as shunts.
