I use a differential amplifier with op07 to amplify voltage drop of a shunt resistor, i set the gain to 17.4. The problem the output of the opamp is very noisy, supply voltages are clean (< 10mV), but the problem is that it's an electronic load, has common gnd and so the noisy voltage from cheap smps that i'm testing gets in the opamp input, so i need to add a filter, or maybe there is a different way to solve this?, i'm gonna try rc, since the opamp inputs use very low current (< 1uA) i can use few k value resistors and 100nF cap, not sure if i should place it on the both inputs or on the output or even both. I found a few schematics on the internet that look ok, but the problem is that max voltage will be 150V, and if i place a cap between input and gnd the difference of potentials will be 150V which will require a physically bigger cap, so i should place it between the inputs like in some schematics
