Author Topic: Difficulty finding suitable DC-DC  (Read 721 times)
Offline RoGTopic starter
« on: July 04, 2025, 03:08:01 pm »
I have been struggling to find a high efficiency (95%+) buck or buck boost (ideally) DC-DC converter with the following specs:
Input 40V to 60VDC (minimum)  11V to 60VDC (desired)
Output 27VDC (minimum)  32VDC (desired)
Output current 40 amps (minimum)
Closest thing I have found is a board mount module that does have enticing specs of 9-60VDC input, 0-60VDC output and 50 amp output current.
It seems to be unobtainium though.  This is the product:  H60SB0A050NRDC by Delta
https://www.digikey.com/en/products/detail/delta-electronics/H60SB0A050NRDC/9598973?s=N4IgjCBcoLQCxVAYygMwIYBsDOBTANCAG4B2aWehA9lANogBsDYAHAOwgC6hADgC5QQIAL6igA
Offline coromonadalix
Re: Difficulty finding suitable DC-DC
« Reply #1 on: July 04, 2025, 04:02:52 pm »
unless you go for thing like theses,  your delta dc-dc  has a very long lead time, and 0 qty on all major sites ...
https://www.aliexpress.com/item/1005009213877532.html?   but 25 amps ?
https://www.icstation.com/1200w-high-power-boost-converter-step-transformer-adjustable-charging-power-supply-electric-vehicles-solar-power-p-16135.html     20 amps
or put them in parallel if your output voltage and or current are fixed ?
https://www.aliexpress.com/item/1005007345671169.html?  40 amps ?
as for reliability ?
Offline mtwieg
« Reply #2 on: July 04, 2025, 04:37:31 pm »
Even your minimum requirements are pretty specialized (>1kW out, with a peculiar output voltage), not something I would expect to find regularly stocked at digikey/mouser.
Are you looking for a one-off, or do you intend to use it in a product? If the latter I would reach out to Delta/TDK/Vicor/Artesyn/etc.
The following users thanked this post: Someone, tooki
