Author Topic: Dimming with Constant Current LED Power Supply  (Read 850 times)
Offline lmagalhaesTopic starter
  • Country: pt
« on: July 08, 2020, 03:18:03 pm »
Hey there,
I have a HLG-320H-C700B LED Power supply and I wanted to have a custom PCB with 4 rows of LEDs of different colors. Then, I'd like to have 4 controls of 0-10V to dim each row individually. Is this at all possible?
With an opamp sensing a resistor on the beggining of each LED string would this be possible? I'm not used to working with constant current supplies. How would it handle this situation ? How would it determine the output voltage ? Would adding another resistor in order to drop the remaining voltage be enough ? It has a maximum of 700mA in total, but they could be distributed, in theory, in anyway for those 4 LED rows right?
Let me know if I'm just wasting time trying to figure this one out.
Luís
Offline Marco
Re: Dimming with Constant Current LED Power Supply
« Reply #1 on: July 08, 2020, 10:58:50 pm »
This is just making life unnecessarily hard on yourself, use a constant voltage power supply and 4 adjustable buck led drivers.
