If a 60V or even a 30V spike ever gets through to V2, the CD4053 will be toast anyway so a low voltage series Schottky pair is entirely adequate, and will offer much better protection due to its lower Vf and much faster operation than any silicon PN junction diode.
Thank you for sharing your analysis.
R13,
ZD3,
C10 and
C11 were chosen to ensure that a 60V transient entering at
+Vin will NOT make it's way to
+V2 (i.e., will not raise +V2 above 20V). That part of the circuit was built to keep the voltage at +V2 to 20V or less. So with that in mind, I am of course designing this with the understanding that the CD4053 would
not be toast for a short-duration 60V transient at +Vin (where there is also
C1 to attenuate the said 60V transient). And that is why I am not so quick or eager to choose a 30V or even a 40V Schottky clamping diode pair for the I/O pins of the CD4053. That is also why I am curious as to the best "higher voltage Schottky" diode pair for the I/O pins of the CD4053. After doing a bit more thinking on it today, I am considering use of the low-cost 60V 200mA Rhom
RB521SM-60FHT2R for
D6,
D7,
D8 and
D9.
Thank you for pointing out the possibility of a
negative going spike possibly putting 65V across D1. An ease and low-cost fix for that would simply be to use a 400V 1N4004 or similar instead of a 60V Schottky. The larger Vf voltage drop across a 1N4004 wouldn't be a problem for this circuit, especially with external clamping diodes on all I/O pins of the CD4053.
Use of a
Unidirectional TVS at ZD1 would not be the most prudent choice insofar as the current placement of D1 is to the
right of ZD1. If D1 (which acts as Reverse Polarity Protection) was placed at
left of ZD1
AND if D1 is also a high voltage 1N4004 or similar, then a unidirectional TVS would be perfectly safe. But I made the current design in hopes of using a Schottky at D1, mainly for the benefit of a lower Vf. Even so, like I said, using a 1N4004 for D1 in the current design would work fine. Alternatively, I could just use a 100V 1A Schottky (for reverse polarity protection) like a
V1FM10-M3/I or an
SL110PL-TP, which probably would be a more prudent choice than the 60V 2A
DFLS260-7 I use right now in terms of reverse voltage rating and cost.
As to your recommendation about using
1W-rated 100Ω resistors at R1 & R13, I actually use a 1W carbon resistor and an 1SMA4750 1W Zener in a current design that has been mass produced for the last 3 years -- a design that hasn't had any electrical issues. But that 1W resistor eats too much PCB space, and a 0.5W Zener is a tad cheaper, and for the redesign saving space and cost wherever possible is important. But even a 1W resistor is going to see more than 1W for a short duration. And that duration is key. So even if I use a 1/4W 100Ω resistor, if the duration of the spike is short (dozens of milliseconds), the resistor would not heat enough to burn from the current we are talking about in a Load Dump. And seeing Load Dumps are rare, it would not be a case of the said 100Ω resistors being hit often with such high current.
I would appreciate hearing any further thoughts you might have in light of this.
