Author Topic: Disadvantages of Using half-wave instead of full-wave in Pure Sinewave Inverter?  (Read 2258 times)
Online Zero999
  • 0999
Now, returning to your suggestion, how the filter could be done without using a ferrite choke? I hope you get the idea.
By using a lower frequency.
Putting the filter before the transformer will not change how the filtering is done. The only difference is, the transformer doesn't have to pass the high frequency components of the signal, which will dramatically reduce the losses.
Online KerimFTopic starter
  • Country: sy
Thank you for your feedback.
Just to be sure I understand to what you are referring as 'transformer's losses', a 500W transformer under test, for example, draws about 1 A DC from the 12V acid battery when in standby (no load). Do you refer to this kind of loss?
As you know, the extra losses in a loaded transformer are in the wirings (copper), not in the core. At high frequencies, the fundamental 15625 Hz and its harmonics, the resistance of wires increases due to the skin effect.
On the one hand, this increase helps the leakage inductance in filtering at the transformer's output that has a capacitor of a relatively small value.
On the other hand, this also increases the dissipation of the copper.
Unfortunately, since we get lately a couple of hours of electricity only in daylight and the same at night, it is not easy for me to do various tests and measurements anytime I like (I am fortunate for ordering a fluke 200MHz digital scope before year 2011 because this the only tool I have now).
And on my sole desk of work, I have to also test and adjust the various assembled boards of what we produce already.
Also, my acid battery (made locally, supposed to be 100 AH) is somehow old (its internal resistance is around 50mR). And the length of the thick wires (10 mm2) from the battery to the desk had to be around 3m (6m all). This relatively long distance is not a problem at low frequencies and loads. But to supply currents pulsed at 16 Khz, they act as thin wires instead (besides adding an inductive reactance).
My real problem is that, lately, I am almost broken while I have to design new products good enough to compete similar ones in the local market. Yes, there are already pure sine wave inverters in the local market that uses iron transformers which are imported from India, China or made locally. But all of them use transformers, having 1 primary coil, instead of two coils in mine. So, I suppose that their efficiency will be comparable to mine since they also use a SPWM high frequency which is filtered solely by the power transformer to also produce a clean sinewave at 50 Hz.
A philosopher: A living thing has no choice but to execute its pre-programmed instructions embedded in it (known as instincts).
Therefore, the only freedom, a human may have, is his ability to oppose or not his natural robotic nature.
But, by opposing it, such a human becomes no more of this world.
Online Zero999
  • 0999
There are other losses at higher frequencies, than the skin effect.
Losses due to eddy currents and hysteresis also increase, which will also increase the standby power consumption.
I'm not sure if you understood my point about harmonic power. A bi-polar 325V PWM waveform has an RMS voltage of 325V, whilst the demodulated 230V 50Hz waveform only has an RMS voltage of 230V. Putting this excess voltage though the transformer results in additional losses.
Ferrite cores are used at higher frequencies because they have lower hysteresis and eddy losses, but they also aren't as magnetic so it's impractical to use them for large, mains frequency transformers and chokes.
Offline coromonadalix
so far
Lots of talk,    nothing on paper  .....
  • Country: sy
so far
Isn't it also the trend in the great speeches around the world?
Offline Kim Christensen
This may be of interest to you since they briefly discuss using a low frequency transformer:
https://www.ti.com/lit/an/sprabw0d/sprabw0d.pdf
Some key points from the article:
• For a given input voltage, the voltage stress on the transistors is double in case of the push-pull topology than
Half Bridge and Full Bridge configuration.
• The center tapped primary in the case of the push-pull converter limits the operation for a higher VA rating for
the same core size when compared to the Half Bridge and Full Bridge converter.
• To prevent flux walking in the DC-DC stage, the current in both the halves need to be sensed and the duty
cycle needs to be corrected accordingly
« Last Edit: March 19, 2024, 04:03:56 pm by Kim Christensen »
  • Country: sy
I hope you agree with me that, in standby mode (no load), the core losses predominate. So, if the current, supplied by the 12 V battery in this mode, is 1 A DC, we can deduce that the power, lost by the core, is 12 W.
I am afraid that the core loss doesn't increase when the transformer is loaded. Only the coils losses increase.
So, while in square wave inverters most of the wire section is used by the current (the skin effect works at the waveform edges only, 2 times in a cycle), in the sine wave inverters the effective section is smaller. This leads us to use thicker wires in order to reduce the extra power dissipation due to the skin effect.
I can't give more detail till I will have the chance to make more measurements related to powers.
I just know now that the standby power is not too high (though it can be lowered when necessary) and the output voltage is a sinewave, clean from ripple (after adding a relatively small bi-polar capacitance). For instance, without the small output capacitor, very high pulses could be seen on the scope (this time, I protected my 1000V/10MegaOhm probe with a 100K resistor in series because a few years ago I damaged one during a similar experiment).
  • Country: sy
Thank you for providing the key points because I have no more the privilege to access any site related to Texas Instruments (though they were kind to send me many of their data and application books in the 70's).
Let us see each point:
[1]
"For a given input voltage, the voltage stress on the transistors is double in case of the push-pull topology than Half Bridge and Full Bridge configuration."
This is not a problem now because...
The typical 55V DS voltage is good for 12V battery.
The typical 100V DS voltage is good for 24V battery.
[2]
"The center tapped primary in the case of the push-pull converter limits the operation for a higher VA rating for the same core size when compared to the Half Bridge and Full Bridge converter."
This is true. In fact, this is the key price of using the simple low-cost topology of push-pull. A bigger transformer is needed for the same VA.
[3]
"To prevent flux walking in the DC-DC stage, the current in both the halves need to be sensed and the duty cycle needs to be corrected accordingly."
I solved this by writing a well precise code (in assembly, as I used to do for 4 decades). And I had the chance to build two discrete MOSFET drivers (3 BJTs each) which work together in harmony very well (1us dead time) while they are driven by the two MCU pins (two anti-phase PWM).
« Last Edit: March 19, 2024, 04:41:32 pm by KerimF »
Offline Xena E
@ KerimF
I'm a little lost now, what I'd like to know is if  this power transformer design you are considering is one that is readily available, or if you have built a prototype from materials that you have available?
If you are trying to use a ready made power transformer 'in reverse' then you are likely to find that copper losses are greater than if a bespoke unit is designed.
Core losses, as in magnetising current at no load can be largely tuned out, so their impact is largely null, though a starting point of only 12 Watts core loss in a 500W (?) Iron component is quite incredible.
The form and order of the windings are also important so as to provide best coupling. You use the term leakage inductance as if it is a good thing, but in this type of project particularly it will have a negative impact on the regulation not to mention efficiency.
You say that efficiency is of no concern provided that it's not 'too' bad, a sine wave inverter based on iron cored inductors working at 50Hz may not exceed a maximum of 60-70% in reality, possibly somewhat less. The suggestion you made of supplying a load of 1kW will create a great deal of heat...
In the conjunction that you synthesised a 50 Hz sine wave from a much higher frequency it would have to be filtered with suitable low loss core materials, and high frequency techniques, not heavy iron.
What I'm also unable to understand is that an inverter that is ready made can be imported into your country for sale but not the components to make a comparable product. Cost cannot be a consideration as the value of the laminations for a transformer core, and the cost of the extra copper required to create a component of high enough inductance for low frequency working, would be far in excess of the cost of suitable ferrite parts. This is the major reason these topologies have dominated.
Please let us help you by including in your next post the details of the proposed project, it's circuit diagram, and the design of any bespoke components.
Best regards,
Xena.
  • Country: sy
Yes, I built a prototype using the same iron laminations which I use for the square wave inverters.
I design everything in a new product (hardware and software) which is made for sale or for my personal need. But I also avoid re-inventing the wheels, mainly if the needed device is cost-effective, like the ready-made SMPS units (but, if necessary, I extend their voltage rating up to 400Vrms by adding an external circuit).
Me too, I wasn't expecting this. But this is what I got.
Today, I tested a well-coupled transformer made for 1000W/12V square wave inverter. Even its tiny leakage inductance was enough to filter the 16Khz PWM with 1uF at the transformer output.
Let us calculate approximately the minimum value of such inductance (Lmin) to do the job.
In an LC low pass filter, if w*L > 20/(w*C), the attenuation (Vout/Vin) is less than 0.13%.
Lmin > 20/(w^2*C)
where
w = 2*pi*F = 2*pi*15625 ~= 98175 rad/s
w^2 ~= 9,638 rad/us
Therefore
Lmin > 20/(w^2*C)
Lmin > 20/(9,638*1uF)
Lmin > 2mH
The leakage inductance seen at the secondary (L_lk, at the high voltage side) could be approximated (assuming Ls_lk ~= Lp_lk*N^2):
L_lk = 2 * Ls*(1-K^2)
Ls = Ls_lk/(1-K^2)/2
where
K is the coupling coefficient
Ls is the secondary inductance measured while the primary is open,
If K=0.9999 we get:
Ls = 0.002/(1-0.9999^2)/2 ~= 5 H
The value 5H is comparable to actual transformer's inductance, seen at its high voltage side.
You may be right.
But, on the one hand, this depends on how much copper will be used.
On the second hand, producing 1000 W or 2000 W inverters doesn't mean that the user will discharge his battery by a permanent 1000W or 2000W load. Actually, the user's average load will be around 350W/700W in this case. The 1000 W or the 2000 W inverter is made to supply the inrush current of certain appliances (like a refrigerator and a water pump).
If it happens that the same transformer does the two required tasks, increasing the voltage and filtering the 50Hz carrier, why do we need looking for something else?
You are right to be confused from where you live.
After year 2011, the local high class only are allowed legitimately to import products from abroad (and behind the scenes, those who are related to, you know, also don't have to pay the taxes which are imposed on the ordinary citizens in case they are allowed to trade).
On the other side, the prices of the imported raw materials (from the small electronic elements to copper and iron) became relatively very high lately due to political sanctions which have been increased exponentially since year 1980.
In brief, after the world saved the people among whom I was born and live, there is no more a local medium class, only high and low classes only (after all, this is the case of all peoples saved by the world since year 2011).
Now, most of my work on this project is on draft papers (I mean not finalized). When I will draw its complete circuit/schematic on Kicad (a very old version, since I have also no privilege to download the newer releases) I will upload its Kicad files and its image for those who can't open them.
Kerim
ahhhhhhhhhhh   still talk talk talk,  nothing more               pfffff  ill leave this thread
After 2 pages of  threads, nothing good will be added, it's time to leave
  • Country: sy
Sorry that you didn’t find around here the answers to the questions in your mind.
On my side, I asked, and I had the chance to hear many interesting answers and hints.
After all, not in vain, it was said 'Ask, and it shall be given you'.
But, in real life, 'asking' is much harder for most people to do than 'giving'. I even met and knew some people who find very hard for them to ask and to give as well. But there are also some others who don’t mind asking whenever in real need and are pleased to answer/give whenever they are asked and they have the means to do it.
« Last Edit: March 20, 2024, 01:21:35 pm by KerimF »
Online Zero999
  • 0999
It's true core losses don't increase when loaded. As you've said, the copper losses will be higher and much higher, given the high frequency content. It's still a silly idea to pass the high frequency content though the transformer. You need to use a much lower frequency. Note how motor inverters use much lower frequencies than this.
I don't see the problem with getting hold of ferrite cores. You must be able to get hold of some old computer power supplies. I wouldn't worry about reusing ferrite cores, just don't do the same with capacitors.
  • Country: sy
I guess you agree with me that this extra heat will exist no matter if the transformer is driven by an H-bridge or push-pull.
So, I wonder how this type of inverters (using H-bridge) were sold locally since many years without hearing any complain about it (from users in the least).
But I still need to do my own studies and tests to have numerical results of the various dissipated powers (even approximately, since I don't have advanced tools and I have one hour daily to work on this, due to lack of electricity). And since all powers, useful and losses, are proportional to the transformer power, my next tests will be on a transformer of 100W only. I will let you know what I will get; for example, the plot of efficiency versus output power.
Yes, I have a few ones. But their number is good for hobby projects, not for production.
Lately, I had the idea to try asking a local retailer (there were tens of retailers before year 2011, now there are just a few ones only) if it is possible for him to order for me a certain quantity of cores/bobbins with a reasonable price. Perhaps this will work.
Meanwhile it is better that I keep working on the project I started with.
  • Country: sy
So far. we (or I in the least) know from experiment that when the iron transformer is open (no load) a small capacitor (as 1uF) at its output shorts the PWM high frequencies (16Khz) while leaving the average of its pulses (50Hz).
In other words, we have here a low pass filter. The problem is that we can think of 3 forms of LPF. They are RC, LC and RLC filters. We have:
L_lk = the total leakage inductance seen at the secondary side.
R_wire = the total effective resistance seen at the secondary side.
Although R_wire is usually small at 50Hz (R_lo), it could become high at 16 Khz (R_hi) at which the effective depth of the wire is around 0.5mm (for copper).
The impedance of 1 uF at 16 Khz is:
Zc = 1/wC ~= 10 Ohms
And we found earlier that we need only 2mH (Z_lk = 20*Zc = 2000 Ohms) as a leakage inductance to get a clean since wave with 1uF.
The question is now:
Is the value of R_hi comparable to reactance Z_lk? Or it is much lower or higher than Z_lk?
In case L_lk is the dominant element in this LPF, it is better to use many thin wires of copper (D=0.5 mm for example) in parallel for the coil's windings. This will decrease both the voltage drop and the coils dissipation when the transformer is loaded. But there is here a trade-off because by using enameled thin wires instead of thicker ones the effective area of the core window will also decrease.
To be continued... if you don't mind.
