Also, methylene chloride. It will swell epoxy...and strip most everything else, too.
Heh, I wouldn't recommend glacial acetic acid (GAA), it will dissolve the core. It's ceramic, sure, but it's not an inert silicate ceramic like porcelain, it's literally ferrite -- that is, ferrate(III), a compound of metals and ferric oxide. Possibly it doesn't dissolve quickly (possibly, the salts don't even dissolve in GAA themselves, so it kind of passivates -- though that seems quite unlikely to me), but it will be etched regardless, I think.
Cores and bobbins are also available from the usual suspects (Digi-key, Mouser) and probably other more regionally specific distributors. Failing that, magnetic suppliers are usually somewhere, broadly local, or continental at least, let's say. I know of several in the US, there ought to be more than a few in EU.
And failing that, well, there's always Ali Express... don't get your hopes up of course, expect everything you order to be a scam, pay accordingly. When received, set up some tests to see if it's as expected.
