There are plenty of ways to build a single-supply current source, if you only care about sourcing current or more generally never need the negative rail. Don't feel the need to stick to the AD8276 or this particular circuit (though both are good).
The main reason people like the integrated difference amps is their on-package, ratio-matched resistor networks. It is usually cheaper to buy one of these guys than to buy resistors of similar specification for rolling your own discrete version. And it gets you a guaranteed performance spec and a bit of extra bandwidth/AC performance (from the excellent capacitive matching inherent to IC processes). But the discrete version is very possible and works well if you get the resistors right. (Consider Vishay Beyschlag ACAS series resistor networks for SMT work; not the best available, but a real bargain for what you get).
Other manufacturers have equivalents to the AD8276. Most notably there is TI/Burr-Brown with a wide range of great parts. I'd look up the best match for you, but they're probably all out of stock anyway. INA592 (equiv. ADI "B grade") or INA597 ("A grade") comes to mind?
If you are just building one of these skip the crazy resistors and just make it tunable. The Pease app note (AN-1515) has some good ideas on how to do that.
