Yay, the saints be praised. Now that wasn't so hard was it? We now have something that we can review and comment on.
My comments:
It would be helpful to others (and yourself later) to include signal names as well as pin numbers so that we don't have to go digging out the datasheet.
You have placed the divide by 2 before the divide by 5. This will give 5MHz and 1MHz as you show ie. overall divide by 10. If you check the datasheet, you will see that the output of the divide by 5 (Q
D) does not have a equal mark:space. A divide by 2 always gives you a 50:50 mark space, so if you place the divide by 5 before the divide by 2, you will get a nice even square wave. Of course, configured this way you will get 2MHZ and 1MHz. If 5MHz is important to you, you can use the unused other half of the chip.
You probably want to experiment with a series resistor, or maybe series capacitor to AC couple the 1MHz output to the 2955A, I can't help you there as I don't know what it's expecting. That's one for experimenting to get most reliable operation.
Edit: @Uunoctium: Snap
