Hello everyone,
I am trying to build a current load based on a PMOS transistor. I need it to simulate a load for another project, where I want to test the hardware, especially the low-side switches, and verify how the PCB handles higher currents. This is the reason why I decided to build the load using a PMOS transistor.
I designed a simple circuit, as shown in the attached schematic, and simulated it. In simulation, it works quite well.
However, after assembling and soldering the circuit, I cannot find a stable operating point. I have tried different values for R72, C36, and C33, but I have not been able to find a combination that allows the circuit to operate smoothly.
I still see oscillations, as shown in the attached oscilloscope capture. The waveform was measured at the gate of the IXTH90P10P transistor.
Could you please help me debug this design? I am running out of ideas about what might be causing the instability or what could be wrong with the circuit.
Thank you in advance for your help!
