Author Topic: DIY Scanning Thermal Camera  (Read 75048 times)
Offline Kaptein QKTopic starter
« on: January 24, 2013, 06:59:37 pm »
Hi, here is some details about my thermal cam project:
I used this IR temperature gun: http://www.ebay.com/itm/150969162727?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
It has a TPS334 thermopile, Op-amp and a ADS1110 AD converter with I2C bus.   I use a Arduino Nano to interface the AD converter and pan/tilt servos.
On the PC side a Processing program displays the result.
See pictures for connections.
Arduino code:
#include <Wire.h>
#include <Servo.h>
Servo pan;
Servo tilt;
int angle;
char charInput;
String command, temp;
void setup()
  pan.attach(2);
  tilt.attach(3);
  Wire.begin();
  Serial.begin(9600);
  pinMode(13, OUTPUT);
  Wire.beginTransmission(0x49);    // thermosensor init
  Wire.write(0b10001110);
  if (Wire.endTransmission()) Serial.println("Error 1");
void loop() {
  command="";
  while (1) {
    charInput = Serial.read();
    if (charInput == '\r') break;
    if (charInput != -1 && charInput != '\n') command += charInput;
  if (command.length() == 8) {
    temp = command.substring(0,4);
    angle = temp.toInt();
    angle = constrain(angle, 1000, 2000);
    pan.writeMicroseconds(angle);
    temp = command.substring(4,8);
    tilt.writeMicroseconds(angle);
    digitalWrite(13,1);
    delay(50);
    digitalWrite(13,0);
    Serial.println(getTemperature());
  else Serial.println(command);
void debug() {
  digitalWrite(13,1);
  delay(100);
  digitalWrite(13,0);
  delay(100);
int getTemperature() {
  byte byteLow, byteHigh;
  Wire.requestFrom(0x49, 2);
  if (Wire.available() != 2) Serial.println("Error 2");
  byteHigh = Wire.read();
  byteLow = Wire.read();
  return byteHigh<<8 | byteLow;
Processing code:
final int xSize = 150;
final int ySize = 150;
import processing.serial.*;
Serial myPort;  // Create object from Serial class
int xPos, yPos, angle, state, temperature, minimum, maximum;
String serialInput;
char charInput;
int[][] temperatureMap = new int[xSize][ySize];
void setup()
  size(xSize*4, ySize*4);
  for (yPos = 0 ; yPos < ySize ; yPos++) {
    for (xPos = 0 ; xPos < xSize ; xPos++) {
      temperatureMap[xPos][yPos] = 0;
  xPos=0;
  yPos=0;
  state=1;
  minimum = 0x7fff;
  maximum = 0x0000;
  myPort = new Serial(this, Serial.list()[1], 9600);
  delay(2000);
  background(0);
void draw() {
  if (state==1) {
    print(xPos);
    print(", ");
    println(yPos);
    angle = 1500 - (-xSize / 2 + xPos ) * 5;  //horizontal FOV
    myPort.write(str(angle));
    angle = 1500 - (-ySize / 2 + yPos ) * 5;  //vertical FOV
    myPort.write('\r');
    if (xPos==0) delay(400);
    drawMap();
    serialInput = "";
    while (true) {
      charInput = myPort.readChar();
      if (charInput != 65535 && charInput != '\n') serialInput += charInput;
    temperature = parseInt(serialInput);
    println(temperature);
    temperatureMap[xPos][yPos] = temperature;
    if (temperature > maximum) maximum = temperature;
    if (temperature < minimum) minimum = temperature;
    println(minimum);
    println(maximum);
    xPos++;
    if (xPos==xSize) {
      xPos=0;
      yPos++;
      if (yPos==ySize) state=0;
void drawMap() {
  int x, y, temp;
  float gain, colour;
  color c;
  gain = 256.0 / (float)(maximum - minimum + 1);
  println(gain);
  for (y = 0 ; y < ySize ; y++) {
    for (x = 0 ; x < xSize ; x++) {
      temp = temperatureMap[x][y];
      if (temp != 0) {
        colour = (float)(temp - minimum) * gain;
        stroke(colour);
        fill(colour);
        rect(x*4,y*4,3,3);
« Last Edit: January 24, 2013, 07:09:45 pm by Kaptein QK »
Online Psi
Re: DIY Scanning Thermal Camera
« Reply #1 on: January 24, 2013, 09:37:45 pm »
Cool.
You could probably speed it up if you used one of those new sensor arrays. Like the 4x16 MLX90620.
They're a bit expensive ($30-100) but still affordable.
That way you'd get more pixels per sample and require less servo movement.
You'd probably need an extra lens, the FOV of those sensors is a bit wide to build a detailed image.
« Last Edit: January 24, 2013, 09:42:17 pm by Psi »
Offline ftransform
« Reply #2 on: January 25, 2013, 08:51:15 am »
Can you post some more details? I want to make one.
« Reply #3 on: January 25, 2013, 04:36:56 pm »
Cool.
I have already speed up the servo movements, so I am quite happy with it.  :)
It is still very slow, but I have good time and it gives a good image, the best I have seen by similar projects on the net.
« Reply #4 on: January 25, 2013, 04:39:44 pm »
Ok, what details do you need?
Offline codeboy2k
« Reply #5 on: January 25, 2013, 06:53:33 pm »
Cool job.. I thought about something like this years ago, but I didn't start anything yet. Maybe you would like to give my idea a try.. basically I thought about using a scanning mirror like a laser printer... a hexagon mirror on a rotating motor, and you can servo it vertically.  If you use it with a line array it might work pretty well.
Offline bombledmonk
« Reply #6 on: January 25, 2013, 07:16:25 pm »
Have you taken a look at the Panasonic grid-eye?  I've been meaning to pick one up, but just haven't had time to work on something new.  It might not be quite suitable for your setup, but it's interesting.
http://www.digikey.com/product-search/en?x=0&y=0&lang=en&site=us&KeyWords=panasonic+grid
http://pewa.panasonic.com/components/built-in-sensors/infrared-array-sensors/grid-eye/
Offline KD0CAC John
« Reply #7 on: January 25, 2013, 07:24:09 pm »
Just in it was missed by some , I did not get in before the deadline but I caught the link .
http://www.kickstarter.com/projects/andyrawson/ir-blue-thermal-imaging-smartphone-accessory?ref=card
Offline svofski
  • Country: ru
    • svo's interactive persuasion vehicle
« Reply #8 on: January 26, 2013, 02:16:12 am »
Really cool, something I've been wanting to build myself for a long time. I also thought about making a mirror system to make it quieter (probably no use to try to make it faster? What's the update speed of the thermopile you're using?)
A little optimization idea: why make a rough turn to the beginning of the next scan line if you can scan in a meander pattern?
The dark boxes are coming
« Reply #9 on: January 26, 2013, 10:43:14 am »
I have not measured it, but is seems reasonably fast. The limiting factor seems to be the slow AD converter.
Good idea, I will try that.
« Last Edit: January 26, 2013, 10:46:31 am by Kaptein QK »
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #10 on: January 26, 2013, 11:06:03 am »
Further optimisation - dynamically adjust scan speed according to rate of change, so flat areas are scanned faster.
Day Job: Mostly LEDs
« Reply #11 on: January 27, 2013, 10:24:16 pm »
I do not know how well that will work here. Already the scanning rate is close to the speed of the AD-converter ( 15 conversions/second )
« Reply #12 on: January 27, 2013, 10:32:26 pm »
I tested this and it did not work well.  The alternating lines where shifted about 3-4 pixels.
I have a new version of the PC-side software that reduces the load on the PC and the scan time. 150x150 pixels take about 30 minutes.
String serialInput;
char charInput;
float gain, previousGain;
void setup()
  xPos=0;
  yPos=0;
  state=1;
  minimum = 0x7fff;
  maximum = 0x0000;
  previousGain = 0;
  delay(2000);
  background(0);
void draw() {
  if (state==1) {
    print(xPos);
    print(", ");
    println(yPos);
    myPort.write('\r');
    serialInput = "";
    while (true) {
    println(minimum);
    println(maximum);
    println(gain);
    if (gain != previousGain) {
      previousGain = gain;
      drawMap();
    else {
      drawPixel(xPos, yPos, temperature);
    xPos++;
    if (xPos==xSize) {
      xPos=0;
      yPos++;
      if (yPos==ySize) {
        state=0;
        myPort.write("15001500\r");
  else {
    drawMap();
void drawMap() {
  int x, y, temp;
      if (temp != 0) {
        drawPixel(x, y, temp);
void drawPixel(int x, int y, int temp) {
  float colour;
  stroke(colour);
  fill(colour);
  rect(x*4,y*4,3,3);
Offline svofski
  • Country: ru
« Reply #13 on: January 28, 2013, 12:38:58 pm »
Yeah, RC servos usually have a lot of play, ~2 degrees is nothing special even in the expensive ones. You can try preloading it by pulling it to one side with a spring or a rubber band.
« Reply #14 on: January 29, 2013, 10:37:23 pm »
I think backlash is only a part of the problem. There is not that much hysteresis in the servo. The sensors time constant and other processing delay also play a role. I either have to slow down the scan (it is now much faster than in the video, about 10 pixels/second) or apply some more processing.
Offline Icewalker
« Reply #15 on: December 01, 2013, 07:23:56 pm »
Hi Kaptein QK,
nice project, thanks for posting the details.
The link to eBay 50:1 is not working, would you please be so kind to post a new one to your featured device.
Thanks a lot in advance.
« Reply #16 on: December 01, 2013, 11:21:13 pm »
I don't remember the name of it, but I think it is this one: http://www.ebay.com/itm/LCD-Digital-Infrarouge-Thermometre-Laser-IR-Sans-Contact-Sonde-De-Temperature-/181207055639?pt=FR_YO_MaisonJardin_Outils_OutilsaMain&var=&hash=item2a30c83d17
I will see if I can find pictures or more info of the model I used.
EDIT: it is NOT the above model. It must have a 50:1 spot ratio.
« Last Edit: December 10, 2013, 03:56:48 pm by Kaptein QK »
Offline cqmiao
  • Country: cn
« Reply #17 on: December 08, 2013, 09:23:34 am »
NB???????Good idea????
My english is too bad~~
Offline AReResearch
« Reply #19 on: December 31, 2013, 11:18:26 am »
Just stumbled across this thread. Your image clarity is amazing!
I have also built a thermal imager a while ago. I used a TMP006 on a breakout board (22$ on ebay).  The results were rather poor because of the huge field of view. Trying to limit that with a plastic straw didn't help a lot. I had to superimpose an optical image to even see what's in the picture.
Has anyone tried the Melexis MLX90614ESF-DCI ? From the datasheet it sounds ideal.
EDIT: Fixed typo.
« Last Edit: January 02, 2014, 04:20:25 pm by AReResearch »
Offline zapta
« Reply #20 on: September 07, 2014, 05:07:07 pm »
Digikey has a USB ready development board for $75  (8 x 8 IR pixels).
http://www.digikey.com/product-detail/en/DKSB1015A/906-1002-ND/4360804
http://eewiki.net/display/projects/Panasonic%20GridEYE%20Breakout%20Board%20and%20GUI
« Reply #21 on: September 07, 2014, 05:24:19 pm »
Unfortunately not available outside US. Presumably as the framerate is 1Hz over the 9Hz limit for requiring an export license.
This guy in France sells a Grid-Eye board :
http://ir-robotics.com/shop/category.php?id_category=6
Offline zapta
« Reply #22 on: September 07, 2014, 05:32:23 pm »
Does it goe by the max rate of the sensor or the entire product? They could limit the rate in the MCU firmware.
« Reply #23 on: September 07, 2014, 05:59:18 pm »
From my reading of it, it's a bit  of a grey area - ITAR can cover components within equipment, but what constitutes a component could be arguable in many cases.
