Your audio adapter has no DC or low frequency response.
Try drawing a square. Then look at the two channels by normal XT and not XY.
My usual test is to generate a square wave to check the transient response. Some audio power amplifiers will produce a clean response, but the DAC or CODEC will not. Tape recordings are especially bad, but none of this matters for audio fidelity.
If you know your stuff and have the right oscilloscope, then the square wave can be transformed into a Bode plot showing amplitude and phase response.
