This morning I repaired the blown FET and tried again, this time probing the drain pin of the FET that usually fails. WSPR has a tune mode that when closed never seems to blow a FET like when it ends a transmission. Now whwther the coding is different for end of the tune mode, compared to the end of a transmission I have no idea, but it's easier to test with tune as it can started and stopped at will, whilst a transmission, as those that know WSPR will be aware, only starts on even minutes and takes 2 minutes to complete. So, IMHO, this is a best case scenario. probe is set X10, so multiply the scale by 10. I had 23V input and it spikes to near 180V when I close the tune mode. I suspect this is what's killing the FETs? I am told they need to be rated 4X the highest input voltage they see. Heaven knows where the spike is at 100V. Am I on the right track, and how should I try and address this please?
