So Let me see if I get this right
Vc to Ve = 12v
Rc=400R
Ic=12v/400R = 0.03A= 30mA
So Ib should then be Ic/10 = 30mA/10 = 3mA
Now Lets take Vb to Ve = 3.0-0.7v drop (Worst Case)
and the Base resistor is 1K,
so Vb/Rb = 2.3/1000 = 0.0023 = 2.3mA
What they had in there Vb to Ve=5v
and Base Resistor is 1K
so Vb/Rb = 5-0.7/1000 = 4.3mA
So (Please tell me if I went wrong with the above).
The Original Voltage of 5V would have driven the transistor into saturation.
and The modified Voltage of 3.3v (my worst case estimate of 3v), means that I am in the linear reigon.
The Relays are holding in, and not buzzing or jittering. What problem could it pose keeping it like that?
P
Figure out your collector current and drive your Ib to 1/10th of it.
You can probably get away with 1/50th of it if Ic is low (100ma or less for example). there is no hard number to go by and no point in doing that.
