I've just started working with the DS18B20 temp sensor. One of the good things is the addressing, it is also the bad thing. Entering addresses is fine for a hobby project, entering addresses in a production environment is not. And then there is that sensor that has to be replaced in the field. My project would only have four sensors so I could devote a pin to each one. There are lots of addressable things out there so there must be a plug and play method out there and I'm just having a brain cloud. There must be a method to put sensors in a string and have a first come first served, RC on power buss? Is this a case where 90% of the code will be devoted to sensor selection? Looking for a clue.
