Loading [MathJax]/extensions/Safe.js
Author Topic: ECL flip-flop help  (Read 3735 times)
Offline allanwTopic starter
    • Electronoblog
ECL flip-flop help
« on: July 24, 2010, 02:34:19 am »
I've been trying to figure out this ECL flip-flop which is a part of the HP 8116A function generator I've been trying to fix. It's an MC10231P: http://www.datasheetcatalog.org/datasheet/motorola/MC10231L.pdf
No matter what I do, I can't get valid outputs from the chip. I've even ordered a replacement for the chip and that one still doesn't work, so I think it's human error.
My connections are like this: voltage source positive end to ground, and negative end to -5.2V rail. I connect -5.2V to pin 8, Vee, and ground to Vcc1 and Vcc2. Hopefully this is correct. The new chip draws 54mA in this state, the old chip I pulled from the 8116A draws 33mA.
The datasheet says the flip flop has asynchronous set/reset, so I've tried setting R = L and S = H (R = -5.2V, S = 0V). Then I measured the outputs to be Q = +0.15V and ~Q = 0V. Then I flipped R = H and S = L, and the outputs were Q = 0V and ~Q = +0.07V. I've even tried clocking it with D = L and H, and R = L, S = L but nothing happens either. What am I doing wrong here? :/
Offline jahonen
Re: ECL flip-flop help
« Reply #1 on: July 24, 2010, 11:48:27 am »
I think that ECL outputs need a termination voltage via resistor to work correctly. For details, see Termination of ECL Logic Devices.
Regards,
Janne
Offline Time
« Reply #2 on: July 25, 2010, 01:01:49 am »
Are you testing the chip by itself or are you testing the chip on the actual PCB of the function generator?
-Time
    • Electronoblog
« Reply #3 on: July 25, 2010, 01:42:43 am »
Regards,
Janne
I think you're right. I'll try terminating the outputs with 100 ohm to -2V.
I'm testing the flip flop out of circuit.
