At this time I need to start a timer to wait for T1 seconds (need to be adjustable in range of 0 to 20 sec with potentiometer)
After T1 I Need to switch TTL signal (going to optocoupler) for T2 seconds (need to be adjustable in range of 60 secs to 120 secs with potentiometer)
I would like to achieve this with some gate and probably one or 2 x 555.
You could cobble something with 555, but those are long time constants, and timing becomes a lottery.
If your tutor says do not use MCU, then smarter would be to use CMOS counters like 4060/4521/4541, which allow much faster RC oscillators and more precision
You can select a choice of two pots with a SPDT analog switch, so chosen out = LOW = t1_POT and out = HI = t2_POT
One counter/divider then manages both delay and pulse times.
Zero time is not a real thing, so you need to choose some sensible pot ratio eg 100:1 for T1 gives 0.2s-20s or 20:1 gives 1s-20s
Add a schmitt part like 74HCS74 or 74HCS72 for your choice of _/= or =\_ trigger and you are done. (eg uses a 74HCS72 to halt after pulse =\_ )
