@Steven Pietrobon Nice work that. Although to be honest I have read your blog several times before.
It seems so primitive now but I can imagine that in 1974 it was still primitive
but would have been quite an exciting platform to learn about computers.
Can you attach some of the photos here. The links now require some form of login and I remember that wasn't the case.
I used to think it a stroke of bad luck that the EDUC8 was pipped by a month by the Mark-8 in an American magazine but I have since found out there was a design published in the Dutch Elektor in 1974 called computer-74. So There may be even more around that time in other non English speaking countries.
One thing I find interesting is that the EDUC8 was a bit-serial design where the bytes were serially clocked around much like the very early vacuum tube designs like CSIRAC. And even though the MARK-8 used the 8008 microprocessor chip I have only in the past year learned that the 8008 also started out as a serial TTL design in the Datapoint 2002 terminal. Intel and Texas Instruments couldn't make this chip operate fast enough or cheap enough for the clients needs so they went with a TTL design initially.
I posted a scanned cover of the EDUC8 with Jim Rowe from 1974 yesterday. Maybe it isn't a complete coincidence you posted.
https://www.eevblog.com/forum/eevdiscover/suggestion-for-eevdiscover-videos/msg1711151/#msg1711151If it isn't possible possible to get Jim Rowe and his original prototype together for a video then you and your EDUC-8 together with Jim Rowe would be pretty good. As I was doing a bit of housekeeping here I noticed I have been asking for that for 5 years. I initially thought the 40th anniversary would have been an opportune time.
I wonder if there are other EDUC8's out there.
Anyway thanks for joining up and sharing.
PS. There is a vintage computing section on this forum you may like to use in future.
