It says "Programming Flash ...".
Flash are certainly programmed different way than EPROMs and EEPROMs.
If it is only just text and really says "Programming EPROM..." then:
It says: Buffer Data: 0x00 Verify: 0xC3.
As blank element has all bytes 0xFF than when after trying to program 0x00 it is read as 0xC3 it means that some bits got programmed enough to be read as zeros, but not all.
What can be the reason:
- too short programming pulse,
- too small VPP voltage,
- incorrect algorithm (if remember well (it was 1988 when I was doing it) some EPROMs were programmed by single 50ms pulse, others (to make task faster) by serie of 1ms pulses with verification after each pulse and when read correct than extra 5ms pulse to ensure that programming is not too weak.
