Author Topic: EKG front end circuit  (Read 3051 times)
Offline WimberleytechTopic starter
« on: October 26, 2018, 10:05:41 pm »
I started this a few years ago but never finished it.  Now that I am dealing with some issues, I decided to get it to the next step.
The circuit is pretty simple, using and AD624 inamp, followed by two second-order Sallen-Key LPFs...and a gain stage.  Turns out the best quality signal is output from the first filter.  You need enough bandwidth to handle the QRS pulse with enough cutoff to knock out 60Hz.
Baseline wander is troublesome when just trying to get a strip holding the inputs with left and right hand...it is doable but not user friendly.  When actual sensor pads are attached to the chest, I get a very nice waveform.  My pads are old, so I rejuvenate them with a salt-water solution.  Fresh ones would likely perform better.
If I decide to take this further, I will probably move to a different lower-voltage inamp operating from a single supply.
For now, what I have does the job.
Offline tpowell1830
  • Peacefully retired from industry, active in life
Re: EKG front end circuit
« Reply #1 on: October 27, 2018, 12:44:02 am »
bradicardia?
PEACE===>T
Offline t1d
« Reply #2 on: October 27, 2018, 01:08:46 am »
Excellent, WT! I have played around, with these type circuits, a bit, myself. What I discovered is that they use the exact same technology as lie detectors. So, I began to include those circuits, in my web searches, too. Additionally, component manufacturers are beginning to offer HIDs, that interface better with individual, portable and DIY units. The major on-line component suppliers are beginning to carry those parts. Adding respiration rate and sweat detection are not very complicated and give the doctor even more/better information.
Great project, on the assembly! Do well. Keep us informed.
The following users thanked this post: Wimberleytech
Offline SiliconWizard
« Reply #3 on: October 27, 2018, 01:39:46 am »
I'd suggest adding some input protection.
As a side note, you could take a look at the AD8232 which packs a lot of features.
« Reply #4 on: October 27, 2018, 02:25:48 am »
bradicardia?
PVCs
Offline mtdoc
« Reply #5 on: October 27, 2018, 02:28:42 am »
Normal sinus rhythm. Rate just over 60 bpm. Not bradycardia.
« Reply #6 on: October 27, 2018, 02:29:59 am »
That is a nice part...but...my assembly skills are no match for that package!!
« Reply #7 on: October 27, 2018, 02:44:11 am »
It's much like a 0.5mm pitch QFN. Doable with some experience.
There are breakout boards though, if you're interested in playing with this chip and evaluate what it can do.
Sparkfun has one: https://www.sparkfun.com/products/12650
« Reply #8 on: October 27, 2018, 12:58:50 pm »
I could have saved myself some effort!  But I still had some fun.  I will buy one of these and play with it.  Thanks for bringing it to my attention.
« Reply #9 on: October 27, 2018, 01:09:29 pm »
I have one of these: https://store.alivecor.com/products/kardiamobile
Quite amazing little device.
Offline David Hess
  • DavidH
« Reply #10 on: October 31, 2018, 04:57:50 pm »
Why not notch out 60Hz in a separate stage to relax the low pass filter requirements?
This might be a good application for inserting an integrator between the output of the instrumentation amplifier and its reference input to create an AC coupled instrumentation amplifier with a high pass cutoff at a low frequency.
« Last Edit: October 31, 2018, 05:00:31 pm by David Hess »
Offline TimNJ
« Reply #11 on: October 31, 2018, 05:08:07 pm »
Indeed. Did an ECG for my senior design project..never fully finished it, but we used a circuit like that.
DSP filtering, namely an adaptive FIR filter, would be a good fit for this type of signal.
