Author Topic: el cheapo micro-ammeter  (Read 35651 times)
Offline dannyfTopic starter
« on: February 19, 2015, 10:28:40 pm »
In a separate discussion, someone asked how to measure small current. So I thought I would experiment with a cheap ammeter that can go down to ua range -> it actually has the potential to go further down but we will not discuss that now.
The design goal is:
1) cheap -> utilize easy to get jfet or cmos opamps. I will start with a TL082 now but will migrate to LMC6042 later;
2) easy to build -> dual opamp, minimal parts count, perfboard construction;
3) work as an adapter for other meters, like a dmm.
Re: el cheapo micro-ammeter
« Reply #1 on: February 19, 2015, 10:30:38 pm »
The basic topology is simple: an opamp plus a big resistor -> virtual ground feedback ammeter.
we will use another opamp as rail spliter. Battery powered -> TL082 consumes 5 ma so 60 hours of operation. LMC6042 consumes 30ua and no need for a battery switch.
Offline george graves
« Reply #2 on: February 19, 2015, 10:32:11 pm »
subscribed
« Reply #3 on: February 19, 2015, 10:35:45 pm »
I already built a prototype on a breadboard, with a 12v source.
When measuring current in a 9v battery + 1.5Mohm resistor, the output is 0.666v -> fairly close to what you would expect.
I will share a picture later.
« Reply #4 on: February 19, 2015, 10:40:01 pm »
Range selection will be done by wiring different value R3.
10k  -> 1v/100ua
100k -> 1v/10ua
1Meg -> 1v/1ua
10Meg-> 1v/0.1ua
Anything below that gets a little bit tricky as the Ibias for TL082 is 30pa+, depending on the source of the datasheet. Now, Ibias doesn't change very fast so if you just zeroed the meter, the measurement is still good.
But that becomes tedious. A low Ibias opamp would be needed if you intend to go below 1v/1ua. That's where something like LMC6042 would come into play, both for its super low Ibias (2fa) and low current consumption (20ua or so if I recall right).
« Reply #5 on: February 19, 2015, 10:41:40 pm »
The construction will be a little bit tricky, if you wish to go below 1v/1ua: guard ring would be a must as you cannot trust most pcb substrates.
For me, I would just use 3d / point-to-point construction on the input pins.
« Reply #6 on: February 19, 2015, 11:34:52 pm »
Some pictures.
First, the micro-ammeter on a breadboard. Red arrow shows the range setting resistor R3 (=100k here). Green box shows Ibias generator.
« Reply #7 on: February 19, 2015, 11:40:23 pm »
Running the meter at ~10v.
Measuring current in a loop with 9v battery + 1.5Mohm resistor -> 0.6v output expected. We measured twice, reversing the battery polarity.
If the meter is perfectly zeroed, we would expect identical readings and with opposite signs.
« Reply #8 on: February 19, 2015, 11:44:16 pm »
Same meter, unzeroed, running under 5v. Swinging shouldn't be a problem but we will have offset. So the difference between the two readings should be about 1140 (571mv - (569mv) = 1140mv).
We got two readings, 539mv and (599mv), for a difference of 1138mv, vs. 1140mv expected. Not bad.
« Reply #9 on: February 19, 2015, 11:46:56 pm »
The Ibias generator has an adjustment range of about +/- 17mv, at 10v power supply, vs Vos of 10mv.
That range is greatly reduced at 5v so I could never zero the readings with this particular Ibias generator. However, if I were to reduce the value of R6 to 1Meg, zeroing becomes possible.
So when you design for your particular implementation, keep that in mind.
« Reply #10 on: February 19, 2015, 11:48:32 pm »
You may also notice that I used 100K resistors rather than 1Meg resistor for my build, purely for convenience as I don't have 1Meg resistors handy. It also tells you how unimportant those resistors are, value-wise.
I will play with other dual jfet opamps and see how that they perform.
« Reply #11 on: February 20, 2015, 12:08:57 am »
Here is the meter utilizing a KF353 (LF353 by Fairchild). LF353 has higher Vos so I was not able to quite zero the meter (1mv off) but good enough.
So the meter is actually quite tolerant of the opamp choices. I am sufficiently comfident that if you build it around other jfet opamps (including the quads) it would work just as well.
« Reply #12 on: February 20, 2015, 12:18:52 am »
Voltage sensitivity:
Ran the meter at 12v and then 10v on the same current.
Reading: 5.71ua vs. 5.72ua.
« Reply #13 on: February 20, 2015, 01:51:37 am »
Identical implementation by someone else: http://www.vk2zay.net/article/251
His unit was built around lmc662(the same family with LMC6042.
Notice how the constructed the input? :) Absolutely necessary for a picometer.
Well done.
Online Vgkid
« Reply #14 on: February 20, 2015, 07:20:38 am »
Is the bias generator used to null out the opamp input bias currents?
« Reply #15 on: February 20, 2015, 12:12:56 pm »
Yes.
The difficult with nulling that current is that its direction changes from one opamp to another. The schematic showed a Vcc connection and if you notice my breadboard construction it was actually connected to Vee.
Just something to keep in mind.
« Reply #16 on: February 20, 2015, 01:49:36 pm »
Measuring the photodiode current from a led, using a 10Meg ohm feedback resistor -> 1v/0.1ua. The 9v battery is not in the circuit.
6.5mv -> 0.65na.
The readings would fluctuate under a led lightbulb, and as you wave your hands. So in real life, shielding would be a must.
« Reply #17 on: February 20, 2015, 01:50:39 pm »
The reading when the led is reverse biased by the 9v battery is 11mv -> 1.1na.
Offline babysitter
  • pushing silicon at work
« Reply #18 on: February 20, 2015, 02:21:13 pm »
If you are on a budget and dont wan't to solder, there is something else you have to measure low currents.El-even-cheaper.
Basically a voltmeter in parallel with 10 Megaohm...a voltmeter in parallel with 10 Megaohm...a voltmeter in parallel with 10 Megaohm...
Yes, your garden variety dmm with 10 Megaohm impedance :-)
(exact value may vary but no one prohibits you from finding out :))
I'm not a feature, I'm a bug! ARC DG3HDA
Offline Kalvin
  • Embedded SW/HW.
« Reply #19 on: February 20, 2015, 03:48:57 pm »
Well done.
The 1 gigaohm resistor maybe something which is not easily found. You can split that huge resistor into three smaller ones (See R2, R3 and R4 in the schematics attached). The schematics shows a measurement circuit for 1nA using more common component values. For the simulation purposes the voltage source provides a 1V step voltage which is fed through a large (1 gigaohm) resistor into the measurement circuitry giving a 1nA to be measured.
« Last Edit: February 20, 2015, 03:58:37 pm by Kalvin »
Offline DmitryL
« Reply #20 on: February 20, 2015, 03:59:47 pm »
What's wrong with existing uCurrent design ? Works pretty well.
« Reply #21 on: February 20, 2015, 04:18:09 pm »
In an I-V converter, you try your best to avoid the use of small value resistors to minimize johnson noise. If you look at commercial picometers, they all use high value resistors, some as high as 1Tohm.
Yes, they are expensive, though glass resistors are a lot more available now, especially from China. The polymer types however aren't that great.
« Reply #22 on: February 20, 2015, 05:23:06 pm »
Put an electrolytic capacitor under test, for its leakage current.
Feedback capacitor is 100Kohm. So gain is 1v/10ua.
When the capacitor is charged under the right polarity, the leakage current is 0.34ua - picture on the right;
When the capacitor is charged under the wrong polarity, the leakage current is 11.7ua - picture on the left, ~40x bigger.
Really leaky capacitors, if I may say so.
« Reply #23 on: February 20, 2015, 05:24:56 pm »
I haven't seen it.
Offline DmitryL
« Reply #24 on: February 20, 2015, 05:30:51 pm »
I haven't seen it.
LOL! What a fun :) try to search by this keyword on this site.
