I'm using an ATX power supply to power my project. I was struggling with spurious (but oddly regular) glitches on some signal lines. After eliminating everything else, I finally disconnected the power supply and put a scope on its unloaded 5V line. The image below is what I saw. (This is even with the PSU's fan not running, because there's so little load.)
It looks like the the same frequency as the glitches on my signals.
Should I just put big capacitors on it, or is there no hope for this PSU?
Thank you.
