Author Topic: Electromagnetic interferences - how to handle?  (Read 1237 times)
Offline reptkeuTopic starter
« on: January 26, 2020, 03:32:22 pm »
Hi everyone,
I'm working on a little DIY lamp project with a capacitive switch.
The kit consists of a breadboard with some components, a battery and its charging PCB, and a 20cm-long electric wire that leads to the aluminium foil used as capacitive sensor.
The lamp switch on and off randomly when in proximity of things, particularly as it nears other electronic devices.
I believe this is due to electromagnetic interferences (EMI) affecting the electronic components.
I'm wondering how I could fix the problem. I know EMC is a bit of black magic, but perhaps there are simple steps to address the issue, at least partially?
I don't think I'm confident enough to delve into active shielding, so I'm looking for simpler passive options. Perhaps someone can help me find a good solution?
Would it work to wrap my breadboard with aluminium foil?
Is it possible to use a shielded cable for the 20cm cable leading to the capacitive sensor (aluminium foil)?
Also, I have found electronic PCB using capacitive switches. Some parts seem to be covered with a yellow paste. Could this paste be a shield? Could I use something similar?
Thanks in advance for your help!
Offline 741
    • Circuit & PCB Design (small PCB quantities OK)
Re: Electromagnetic interferences - how to handle?
« Reply #1 on: January 26, 2020, 09:57:27 pm »
Perhaps use thin shielded wire, the PCB-side braid tied to Vss?
Also, maybe reduce capacitance by inserting a series capacitor of similar value to the sensor (wild guess: 22pF, I've no idea really though  :))
