Lets see if photobucket works today
Always tricky to figure out which service actually works at any gives time.
Well cool, that seems to have worked.
Now that looks a little bit like a posed photo rather than someone actually soldering
If your daughter were to hold the soldering iron more like a pencil, and also pull a length of solder from the holder and hold the solder wire directly that would give more control and finesse over the soldering process.
Also, perhaps you might encourage your daughter to wear safety glasses? It's possible for small drops of solder to splash or fly about, or for small bits of wire to go flying when you snip them, and these are not good if they land in an eye. Ignoring eye protection is a risk adults usually take, but children are not mature enough to know the risk and be able to make an informed decision about it.
Here are some videos you might watch with your daughter for inspiration if you are not already aware of them:
http://sylviashow.com/episodesI note that Sylvia doesn't always wear eye protection either, but she does when clipping component leads (adults should do so too).
