Author Topic: Enclosure for matrix board  (Read 1659 times)
Offline The ChumpTopic starter
« on: July 06, 2020, 02:27:13 pm »
Does anyone know of any plastic enclosures that have mounting posts compatible with these standard matrix boards?
https://uk.farnell.com/multicomp/mc01007/prototype-board-phenolic-72mm/dp/2768277
(Also available from other suppliers/manufacturers with varying part numbers)
Thanks,
Alex
Offline rdl
Re: Enclosure for matrix board
« Reply #1 on: July 06, 2020, 08:59:10 pm »
I know of a few places that sell boards made for specific boxes, but they're all here in the US. BBP makes boards for some specific Hammond boxes. MPJA sells some cheap boards to fit some cheap boxes they sell. There are probably others. Seems like there would surely be somebody selling board/box kits on eBay or Amazon, etc.
http://busboard.com/pcbhammondbox
https://www.mpja.com/3-3_16in-X-2-1_2in-Protoboard-for-15913-BX-Box/productinfo/15914+PB/
« Reply #2 on: July 07, 2020, 11:00:33 pm »
Interesting, but I have these boards and am looking for a box...
Offline wizard69
« Reply #3 on: July 09, 2020, 05:08:34 am »
Measure up the board and go looking on the various box manufactures web sites.   It is doubtful you will find an exact fit.
« Reply #4 on: July 09, 2020, 09:45:07 am »
Already exhausted myself doing that. Dimensions are provided in the datasheet from Farnell. Nothing seems to be even close.
 I'm posting here on the off-chance that someone else found something.
Offline Boxgirl
« Reply #5 on: July 09, 2020, 03:04:31 pm »
Hammond Electronics sell a wide range of Electronic enclosures. Maybe try contacting them? :)
Offline rdl
« Reply #6 on: July 09, 2020, 05:12:00 pm »
Personally, I'd toss the board and look for a better solution. Consider it a cheap lesson, when designing a project that will go in a box, start with the box and make everything else fit.
« Reply #7 on: July 09, 2020, 09:08:14 pm »
Thank you for your sage advice. Not quite what I asked for...
Offline rdl
« Reply #8 on: July 09, 2020, 09:32:56 pm »
Another possibility is the type of case where you slide the board into card guides instead of screwing it to posts. All you'd need to do is get the width reasonably close and make sure it's long enough and thick enough for the rest of your parts to fit.
Similar to this kit set up.
https://www.amazon.com/PR2H1-ProtoBoard-Box1-Kit-KBOX1-AC-SV-PR2H/dp/B00W865BGW/
Offline themadhippy
« Reply #9 on: July 09, 2020, 09:50:46 pm »
Buy a  suitable size  box and add your own mounting posts,either by drilling some holes and using nuts and bolts or if holes are a no, adhesive pillars
