Author Topic: ESR meter again...  (Read 6002 times)
Offline zaokaTopic starter
ESR meter again...
« on: December 30, 2010, 01:44:04 am »
From all of the schematics available online does any have large scale from 0-1R?? This is most important measurement range and most of the schematics are built so that 0-1R range takes only 5% of the full analog meter deflection...
I would love to build one meter that has 2 ranges:
0 - 50R
0 - 5R
This way we can test those 1000uF and up with accuracy.
 ::) ;D
Offline Psi
Re: ESR meter again...
« Reply #1 on: December 30, 2010, 02:31:39 am »
probably not the answer you were looking for but personally id buy one rather than build one. I'm not really a fan of building test equipment when a bought one is available at a good price and is likely to be better anyway.
Having said that, you do learn a lot from making your own gear so if thats the goal, go for it.
If i needed one id probably buy this for ~ US$129 + $12pnp
(I'm quite pleased with my LCR and component tester from them)
http://www.peakelec.co.uk/acatalog/jz_esr70.html
  • Measure capacitance and ESR.
  • New enhanced dynamic range of 0.00 to 40.0 ohms.
  • ESR Resolution as fine as 0.01 ohms
  • Supports capacitors from 1uF to 22,000uF.
  • Capable of In-Circuit measurement of ESR.
  • Polarity free, connect any way round.
  • Great for low DC resistance checking too
  • Protected against highly charged capacitors
  • Tests at the industry standard 100kHz.
  • Automatically carries out a controlled discharge procedure
They also make a cheaper one for US$109 which only goes to 20R instead of 40R
http://www.peakelec.co.uk/acatalog/jz_esr60.html
« Last Edit: December 30, 2010, 02:44:04 am by Psi »
Offline tjw
« Reply #2 on: December 30, 2010, 12:13:55 pm »
    have you seen Bob Parker's ESR meter ? Have a look here http://members.ozemail.com.au/~bobpar/
It uses a Zilog Z8 MCU and is a top class product. Full schematic and a description of the circuit operation is supplied with the kit. Bob has a lot of information on his site about the meter and how to use it.
I have built one and prefer it to a commercial unit since I can fix it if there are problems and I learnt something along the way.
I recall that these kits were being sold in the US a few years ago, but cannot remember who was selling it. In Australia you can get it here http://www.altronics.com.au/index.asp?area=item&id=K2574
Regards, tjw.
Offline tyblu
    • blog.tyblu.ca
« Reply #3 on: December 30, 2010, 05:00:28 pm »
Great link tjw
Tyler Lucas, electronics hobbyist
Offline Zyvek
« Reply #4 on: December 30, 2010, 08:43:06 pm »
I have this meter and I'm pretty happy with it, I also considered the Blue ESR  Bob Parker meter as well, but I liked the extra bells and whistles the ESR70 provided. I'd love to see a head to head comparison.
« Last Edit: December 30, 2010, 10:16:23 pm by Zyvek »
-Z
Offline Psi
« Reply #5 on: December 30, 2010, 09:52:00 pm »
I have this meter and I'm pretty happy with it, I also considered the Blue ESR meter as well, but I liked the extra bells and whistles the ESR70 provided. I'd love to see a head to head comparison.
i think you mean the other purple one that's a little cheaper, the blue one is the component tester for testing transistors fets diode leds etc..
I have the yellow LCR and the blue DCA and i may get the purple ESR70 and red SCR at some point in the future.
« Last Edit: December 30, 2010, 09:54:44 pm by Psi »
Offline Zyvek
« Reply #6 on: December 30, 2010, 10:14:38 pm »
Doh, Sorry for the mix up, I actually have the ESR70 (Purple) , the DCA55 (Blue) and the LCR40 (Yellow) meters.  I'm happy with all three, even if I can't keep the model #'s straight.
-Z
« Reply #7 on: December 31, 2010, 12:09:44 am »
I want to build analog meter, I found it better than digital... Its faster to work with.
The reason I want to build one is because I want to make it with a large analog instrument, the ones you can buy are all with small instrument.
I bought MUL3333 but its 0-1R measuing range is so small.
Looks like a people who have no expirience in repairing stuff are the one who design this kind of stuff..
