Author Topic: esr tester  (Read 1204 times)
Offline pete gTopic starter
esr tester
« on: April 15, 2025, 06:46:45 pm »
hi, i would like to construct the j diddy esr meter with short detect. is there a thru hole version of the pcb for this project?
Offline moffy
Re: esr tester
« Reply #1 on: April 16, 2025, 05:33:24 am »
You could do as the poster in this did and just use a generic breadboard: https://www.eevblog.com/forum/projects/5-transistor-esr-meter-design/msg4594744/#msg4594744
Re: esr tester
« Reply #2 on: April 16, 2025, 04:07:42 pm »
hi, i'am 88 years old and need a pcb to make any project.
Offline RAPo
Re: esr tester
« Reply #3 on: April 16, 2025, 04:20:32 pm »
The zip in the download on this page has a PCB. Is that what you are looking for?
Re: esr tester
« Reply #4 on: April 16, 2025, 05:35:58 pm »
hi and thanks for replying. no the project was a 7 transistor j diddy b design. he designed two versions. one had 5 transistors with no short detect. the other 7 transistors with. he never published a thru hold pcb for the 7 transistor version.
