Picked a couple of these up quite awhile back, one with a pretty busted up front panel, and have been meaning to schematic the thing up for far too long. This is not what I personally consider a 100% complete schematic, as I prefer to strip the board, scan it, then rebuild it in software from the schematic to confirm everything connects where it actually does, but I'd like to (eventually) put this one back into service without having to rebuild it from scratch so I didn't get real invasive, but it should be mostly complete.
I also have not tossed her back together and tweaked all of the POTs, so the unknowns are marked with a ? in there. There seem to be multiple revisions of this thing also, as both of mine are, one has the Toroidal style transformer and CH3/CH4 Regulators built into the control board, while the one I made the schematic from has the Laminated transformer and the CH3/CH4 Regulators as plug in boards, so expect some differences between these schematics and your boards.
If anyone spots anything that looks wrong or what not let me know and I'll tweak the schematics accordingly.
A couple of things that I found interesting were how in the manual for Series operation it states (5. The user must physically short the negative terminal of the Master output with the positive terminal of the Slaved output.) but when you press S501 that turns on RL506 and it does that internally.
Then for Parallel operation it also states (4. The user must short the two positive terminals. 5. The user must also short the two negative terminals.) Which the thing also seems to do internally, but I don't get how RL507 is turning on the way they have it in there?
POWER BOARD - RS1340_2A 2011_4_15 -
Schematic - ExTech 382270_RS1340_2A.pdf (121.09 kB - downloaded 147 times.)
DISPLAY BOARD - RS1340_B3 08_07_03
Schematic - ExTech 382270_RS1340_B3_08_07_03.pdf (190.81 kB - downloaded 60 times.)
DISPLAY BOARD - RS1340_B3 2017_03_8
Schematic - ExTech 382270_RS1340_B3.pdf (179.31 kB - downloaded 75 times.)
CH3 REGULATOR BOARD - No Markings -
Schematic - ExTech 382270_3-6.5v_CH3.pdf (43.52 kB - downloaded 102 times.)
CH4 REGULATOR BOARD - No Markings -
Schematic - ExTech 382270_8-15v_CH4.pdf (42.98 kB - downloaded 79 times.)
CONTROL BOARD - RS1340_23 081126 -
Schematic - ExTech 382270_RS1340_23_081126.pdf (346.16 kB - downloaded 55 times.)
CONTROL BOARD - RS1340_23 170225 -
Schematic - ExTech 382270_RS1340_23_170225.pdf (286.85 kB - downloaded 57 times.)
TOP RS1340_23 170225 (NOTE: All TH components have been removed to scan board)
BOTTOM RS1340_23 170225 (NOTE: All TH components have been removed to scan board)
