EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
F5152-1 info
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: F5152-1 info (Read 3604 times)
nonsuchpro
Contributor
Country:
F5152-1 info
on:
November 24, 2014, 08:02:33 am »
Hello all.
New to the forum. Been watching the videos for about a year now. Great stuff!!
I've acquired a component that I can't find any info for. It's has 6 pins and is labeled F5152-1 on all of them, all the other numbers change. Anybody have any idea what it is? I'm thinking an op-amp or some kind of darlington but have no clue.
Thanks in advance!
Rob
Logged
philpem
Frequent Contributor
Country:
That Sneaky British Bloke
Re: F5152-1 info
Reply #1 on:
November 24, 2014, 12:58:02 pm »
The "F" looks like a manufacturer's logo. Fuji Electric or Fairchild perhaps? Have a look at a semiconductor manufacturers' logo website and see if you can match it up.
http://www.elnec.com/support/ic-logos/?method=logo
might be worth a try, or
http://www.siliconinvestigations.com/logos/logos.htm
or
http://www.classiccmp.org/rtellason/logos/semiconductorlogos.html
That leaves 5152-1 as the part number.
Given the 3:3 pinning, my bet is that they're dual matched transistors, possibly JFETs. If you've got a semiconductor analyser (Peak Atlas DCA or similar), you could try connecting the sets of three pins in turn (first the set on one side, then the other). If they're FETs, they should read similarly.
"225" and "227" (read on a few of the parts) is probably a date code, but I can't remember how to decode the old 3-digit codes. It's either YWW or WWY (year-week or week-year) and the year is the last digit of the year. Realistically, YWW is most likely, and I'm guessing 1980s, which would put them at the 25th and 27th week of 1982. That's just a guess though!
Logged
Phil / M0OFX -- Electronics/Software Engineer
"Why do I have a room full of test gear? Why, it saves on the heating bill!"
SeanB
Super Contributor
Country:
Re: F5152-1 info
Reply #2 on:
November 24, 2014, 06:15:00 pm »
Logo is Precision Monolithics, now Analog Devices.
Can't find the 5152, probably well obsolete now, but try to look here for datasheets for similar devices.
http://www.analog.com/en/special-linear-functions/matched-transistors/products/index.html
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: F5152-1 info
Reply #3 on:
November 25, 2014, 03:11:46 am »
What was Ferranti's logo..?
Agree, looks like a dual transistor; if nothing else, you can ohm it and see. Likely candidates: NPN, PNP, N-JFET.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
SeanB
Super Contributor
Country:
Re: F5152-1 info
Reply #4 on:
November 25, 2014, 07:45:19 pm »
I have some 2N2223 transistors in the same package. the pinout should be the same, so you can just use this to check them as individual transistors.
Logged
nonsuchpro
Contributor
Country:
Re: F5152-1 info
Reply #5 on:
November 29, 2014, 12:48:51 am »
Thanks for the replies, much appreciated!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
F5152-1 info
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
