Probably a bad batch with high leakage through the internal diodes. Still likely to be working, but they might be either production test rejects or recycled devices. Photos will show that.
That leakage is high, but might still be usable in straight logic. Try pulling each input low at a time till you find the leaky one, it might be an internal transistor that is leaking.
