Author Topic: Fan sensor output measurement?  (Read 500 times)
Offline pacmannTopic starter
  • Country: jp
« on: July 19, 2025, 06:32:52 pm »
I want to measure the fan speed from a 4 pin SanAce fan. I assume the sensor is open collector? I put 10K and then 1K pull up but the signal is only ever at ground with small 20khz spikes that don't change with speed of the fan. I try with 2 new fans and see the same thing. Do I need to do something else to measure the sensor output?
Offline Uunoctium
Re: Fan sensor output measurement?
« Reply #1 on: July 19, 2025, 07:11:35 pm »
The specs from SanyoDenki = SanAce fans for their pulse sensors:
https://www.sanyodenki.com/archive/document/product/cooling/San_Ace_M0011876.pdf
