Good evening, I'm trying to design a fast thermo-couple compensation circuit, or use an available IC if they can cope with the speed.
I want to use a K-type TC, and want to sense a temperature range between 50ºC and 700ºC(its for an EGT probe), a 1ºC resolution is perfect, but I want to read it at 1Khz, maybe 2Khz if possible, I have already used the Maxim IC's and they are great, plug and measure, but they are way to slow for my use(good for the coolant temperature, but they are pretty expensive even for that).
I have found this Microchip App-note:
http://ww1.microchip.com/downloads/en/DeviceDoc/51889a.pdfSeems a smart idea, just plug the TC directly into the ADC, and add code to do the rest, but a fast 18bit or more ADC is going to be ultra expensive.
Any ideas on what to use?
Best regards.
